heywier427 Posted December 2, 2014 Report Share Posted December 2, 2014 Pretty sure my car was automatic from the factory, as it has the sensor at the back of cluster, and the automatic gas pedal. Question is, now that Im 5 speed, do I need to keep the sensor plugged into the harness/cluster? I doubt it, but cant hurt to ask. And it had 2 sensors double stacked? What was that about? Quote Link to comment
datzenmike Posted December 2, 2014 Report Share Posted December 2, 2014 Maybe the cable was short and this was easy. Leaving it as is won't harm anything. The emissions equipment (mostly dual points, one set retarded) will still think you're driving an automatic and it will run the same. Most likely the emissions system has been deleted, in which case it will run the same. Quote Link to comment
heywier427 Posted December 2, 2014 Author Report Share Posted December 2, 2014 Thanks for the reply. Damn near everything stock is gone, as it is a rotary for the time being. Thanks again. Quote Link to comment
Nuclear Water Boy Posted December 11, 2014 Report Share Posted December 11, 2014 You don't need those any longer. Just get a speedo cable for the automatic being that their longer and fit the longer 5-speed trans. Quote Link to comment
