Eriks Posted November 21, 2014 Report Share Posted November 21, 2014 Many of the L-engine clutch kits for sale are markeded at being for a specific model. E.g. I see kits especially for 160Js and especially for 610 etc. But is it not correct that any 200mm clutch kit will fit any L-engine engine that has a 200mm flywheel ? Quote Link to comment
datzenmike Posted November 21, 2014 Report Share Posted November 21, 2014 Yes they will. The 200mm clutch for an L20B from a later A10/S10/S110/710 is stronger than the one for the L16 in the 510. The release collar is slightly different. Quote Link to comment
banzai510(hainz) Posted November 21, 2014 Report Share Posted November 21, 2014 If you order a 200mm between 1968 thru I think 1974 L16/l18 engines most likely youll be fine. I dont think they had L20s in Norway Quote Link to comment
hobbes_the_cat Posted December 2, 2014 Report Share Posted December 2, 2014 Just make sure the the throw out bearing sleeve/release collar matches the new clutch. Most models are different from one another and the clutch will not engage or dis engage properly with out the matching sleeve/collar. ie: 610 collar with 610 pressure plate, 280zx collar with 280zx pressure plate, ect. Quote Link to comment
