HRH Posted November 9, 2014 Report Share Posted November 9, 2014 So if you've been following the Frontier dohc thread in Gen Tech, you've already seen the pics. If not, I picked up a low miles '84 Maxima wagon in quite good condition this week. This is the new wagoon! These are the other snow wheels I had for the 510. Going to have to acid them up today and get them all shiny like the ones on the truck. I may change to the 6 spoke Z wheels, but we'll see. If I like how the turbines look, I may leave them on. Off to the garage to get started on this cold, wet, rainy day! Supposed to be 14 degrees on Monday night, have to check all the fluids in both Maxima. 5 Quote Link to comment
datzenmike Posted November 9, 2014 Report Share Posted November 9, 2014 Congrats Matt!!!! She's a keeper. 1 Quote Link to comment
HRH Posted November 9, 2014 Author Report Share Posted November 9, 2014 After an hour or two of scrubbing and aciding and washing and aciding, I got the wheels halfway decent. Figured I can clean them up the rest of the way in the summer if I need to. Amazing what a set of wheels does to the car's image. Goes from total blah, to total awesome!!! :D Those tires are a little small, but they are good studless snows. Since I'm not going to drive this in the winter they'll work until we get around to next summer and I figure out which wheels and tires I'll be running. 4 Quote Link to comment
HRH Posted November 9, 2014 Author Report Share Posted November 9, 2014 And here's why mhub, you shouldn't pay more for a "pristine" older Datsun. ;) Not saying it isn't still awesome, but you would think people would change things with 104k on the clock, especially considering it's a 30 year old vehicle. Take a look at these: I drove it home, had no issues. Going about routine maintenance today, I already mentioned the FRAM oil filter. Good news is the oil level was full and not particularly dirty. However, notice the heater hoses next to the oil filter? See anything wrong there? Next I checked the water level. Non-existent. It was about 1-2 quarts low. See anything wrong with this picture? I can't believe nothing broke on the drive home. How about some factory spark plug wires from Sumitomo? Vacuum lines are the same way, all original. DEFINITELY going to be changing all the rubber. Almost forgot this one. Like how the main battery terminal is attached to the bolt, not to the center of the battery post? It's not that bad, but still. Butt connectors for all the power leads. We'll clean those up and solder them. 1 Quote Link to comment
Charlie69 Posted November 9, 2014 Report Share Posted November 9, 2014 Not to mention how the battery acid has traveled thought the fusible link wires crimped to the eyelet connector under the other universal battery cable bolt. Quote Link to comment
Kirden Posted November 9, 2014 Report Share Posted November 9, 2014 If it's not broke he didn't fix it?... Want to buy POs that do regular maintenance. Quote Link to comment
HRH Posted November 10, 2014 Author Report Share Posted November 10, 2014 Yeah, had a nice coating of grease. Like bearing grease all over the connectors. I'm assuming to keep corrosion off, but seriously, wtf? I fixed the idle. It was idling at 2000 rpm. Someone had set the distributor to about 20 or 30 degrees advanced for some reason. They probably didn't know about disconnecting the idle control switch off the ignition module that crops up on those years. Anyway, adjusted the air bleed way down and re-timed it. Works a lot better now. Couldn't seem to find any vacuum leaks, suprisingly. Quote Link to comment
banzai510(hainz) Posted November 10, 2014 Report Share Posted November 10, 2014 I didnt see anyhting in the photos? what was wrong with hoses and ,and what was going to break driving home. I didnt see anything Quote Link to comment
q-tip Posted November 10, 2014 Report Share Posted November 10, 2014 I didnt see anyhting in the photos? what was wrong with hoses and ,and what was going to break driving home. I didnt see anything Yeah, I concur. Low coolant was the only big issue I saw. Quote Link to comment
HRH Posted November 10, 2014 Author Report Share Posted November 10, 2014 Lol. You guys must not do preventative maintenance either. :D 2 Quote Link to comment
]2eDeYe Posted November 10, 2014 Report Share Posted November 10, 2014 Shit, I'd be tempted to run that original stuff just to see how long it will last. :lol: Nice score dude :thumbup: 2 Quote Link to comment
hobospyder Posted November 10, 2014 Report Share Posted November 10, 2014 Heater hoses scare me just because one is looking like it's starting to bulge and they only last so long anyways. Same with that factory belt, don't want to figure how badly that'll Fuck up the car when it goes. Give it a tuneup, change some rubber, drive the piss out of it Nice car though 2 Quote Link to comment
q-tip Posted November 10, 2014 Report Share Posted November 10, 2014 Heater hoses scare me just because one is looking like it's starting to bulge and they only last so long anyways. Same with that factory belt, don't want to figure how badly that'll Fuck up the car when it goes. Give it a tuneup, change some rubber, drive the piss out of it Nice car though Oh come on where is your sense of adventure!? 3 Quote Link to comment
banzai510(hainz) Posted November 10, 2014 Report Share Posted November 10, 2014 Im still not seeing what was wrong? beside the low radiator fluid. and maybe the Fram oil filter they all bludge near the connector far as I know. I try to do prevantive maint but as for hoses mine are all changed mutiple times overand also the belts fuel pumps satrters volt regs ect.................................. To me it looks untouched by a 510 owner thats why the stock grease on the battery cable so you know everything is most likely GOOD and not hacked up by some kid. THOSE HOSES AND BELT IS FINE!!!!!!!! 3 Quote Link to comment
hobospyder Posted November 10, 2014 Report Share Posted November 10, 2014 Oh come on where is your sense of adventure!?I've shredded a timing belt in a 86 Celica. Lucked out that it was a non interference motor. Quote Link to comment
q-tip Posted November 10, 2014 Report Share Posted November 10, 2014 Unless its dried out and cracked out bulging badly its fine. Quote Link to comment
datzenmike Posted November 10, 2014 Report Share Posted November 10, 2014 Lol. You guys must not do preventative maintenance either. :D 30 year old plug wires. Probably the original PS pump belt. Rad is getting crusty inside. Heater hoses are soft and swollen. 1 Quote Link to comment
HRH Posted November 11, 2014 Author Report Share Posted November 11, 2014 Okay, waaay too much work done today. I'll have pictures up after I make and eat dinner. If I feel up to it. Short of it, replaced both battery terminals while cussing the moron who covered them in chassis grease, what a fucking mess. Made a battery hold down so the positive doesn't ground out against the power steering box. Luck is all that was and about a 1/16" clearance. Replaced the Autolite plugs with the proper NGK. Replaced the wires, Belden as usual is incorrect in the coil wire size so I borrowed one off an older set of NGK I had when I was swapping parts on the D21. Probably only has 10,000 miles on it. Left the cap and rotor because I didn't have a cap in town go figure. I probably bought the last one for the other Maxima. Replaced all the heater hoses and radiator hoses, with the exception of the two tiny ones on the intake manifold. Not enough time. They look good and don't move ever so I can probably get away with those for a bit longer. Didn't replace the belts either, but I put them in the car in case Regy has to replace them on his drive to the farm tomorrow. Crossing my fingers. Replaced the thermostat and gasket while I was in there too. Then swapped good tires off autocross Maxima and stored in basement. Then put snow tires on red truck and stored good tires in basement. F a duck, I've been busy today. Whew. 2 Quote Link to comment
HRH Posted November 12, 2014 Author Report Share Posted November 12, 2014 Well, the Maxima is down at the farm for paint and body. Unfortunately, with the cold temps, Regy can't get the shop warm enough to start work. Booo! So going to have to wait until the weather breaks a little and it warms up past 20 degrees. Quote Link to comment
ArchetypeDatsun Posted November 13, 2014 Report Share Posted November 13, 2014 Nice find matt same color as my sedan! Quote Link to comment
HRH Posted November 14, 2014 Author Report Share Posted November 14, 2014 Thanks man! I thought yours was white though? Mine's tan, kind of light. Quote Link to comment
captaingamez Posted November 16, 2014 Report Share Posted November 16, 2014 Congrats on the new Maxima man. these cars are addicting aren't they? Okay, waaay too much work done today. I'll have pictures up after I make and eat dinner. If I feel up to it. Short of it, replaced both battery terminals while cussing the moron who covered them in chassis grease, what a fucking mess. Made a battery hold down so the positive doesn't ground out against the power steering box. Luck is all that was and about a 1/16" clearance. Replaced the Autolite plugs with the proper NGK. Replaced the wires, Belden as usual is incorrect in the coil wire size so I borrowed one off an older set of NGK I had when I was swapping parts on the D21. Probably only has 10,000 miles on it. Left the cap and rotor because I didn't have a cap in town go figure. I probably bought the last one for the other Maxima. Replaced all the heater hoses and radiator hoses, with the exception of the two tiny ones on the intake manifold. Not enough time. They look good and don't move ever so I can probably get away with those for a bit longer. Didn't replace the belts either, but I put them in the car in case Regy has to replace them on his drive to the farm tomorrow. Crossing my fingers. Replaced the thermostat and gasket while I was in there too. Then swapped good tires off autocross Maxima and stored in basement. Then put snow tires on red truck and stored good tires in basement. F a duck, I've been busy today. Whew. Great stuff. Change those small lines on the intake or remove them ASAP, thse are the worst ones. I replaced everything else and then what do you know!!Tthe first time I drive the Maxima after all the work, those little bastards blow up and I had to call my wife to stop at the autozone, grab plugs and block it off real fast. 1 Quote Link to comment
HRH Posted November 16, 2014 Author Report Share Posted November 16, 2014 Ah, they're alright. I'm going to have to fix the radiator too, but being 20 degrees right now, I'm not too worried about that. Once I get it back from Regy I'll go about doing the rest of the routine maintenance I still need to do. Like re-sealing the intake/exhaust gasket. It's not blown out, which means it's just waiting for summer. Plus it doesn't look like any studs are broken so I'll probably yank the manifolds and replace all the studs before they have a chance to break as well. Lots of work to be done, but I have all winter. Going to try and clean out my garage today so I can store the parts I'm yanking off the other Maxima in case I need spares for the wagon. It's a shame the interiors aren't the same color. And thanks! I'm pretty stoked. Was going to sell the white truck today but the kid's check didn't come in. Hopefully it will arrive in the mail tomorrow and he'll make a late trip down here. That will give me the rest of the cash I need to pay off what I borrowed for the new acquisition. Quote Link to comment
HRH Posted November 19, 2014 Author Report Share Posted November 19, 2014 So I took a trip to Lewiston this weekend to get a fender for the wagon. Quite fun, here are some oics! Palouse Highway A wild haystack in it's natural habitat. Or maybe that's a straw stack. Not sure. Molly was very happy about getting to go. Clearwater River. New (used) fender! I also stopped by and saw Mohammed after I picked up the fender. He transferred to Lewis and Clark State College in Idaho from Eastern, so we bullshitted about L20 motors and turbos and you know, blah blah blah, Datsuns for a while! ;) Sadly I forgot to take a picture. 2 Quote Link to comment
HRH Posted November 23, 2014 Author Report Share Posted November 23, 2014 So I'm half tempted to put the new wheels on the wagon. I still need 8" wide wheels for the 225 race tires, but the 5 spokes would look sexy on the wagon. Not quite sure yet. Going to bring a few to Regy's on Monday and test fit them. They would need some rolling, but possibly only on the front as the rear may be a less wide track due to the solid axle. Don't know, we'll see. I may still do something else. 1 Quote Link to comment
