red13 Posted May 3, 2015 Report Share Posted May 3, 2015 Thanks, there was enough adjustment to eliminate most of the slop. I checked for binding while the wheels were up in the air, it seems good. Right now I've got the drive shaft out and the transmission backed away enough to have the clutch and pressure plate removed. I'm having trouble getting the transmission to drop out completely, is there a trick to it? check to see if the shifter is catching on the top. 1 Quote Link to comment
SadieD Posted May 4, 2015 Author Report Share Posted May 4, 2015 check to see if the shifter is catching on the top. Yea that's kind of the problem. I removed that extra sheetmetal cover that goes around the gear shift hole, I'm gonna try again tomorrow. Also, if your truck is crusty like mine is and you're pulling your transmission, think about doing the u-joints. 1 Quote Link to comment
SadieD Posted May 4, 2015 Author Report Share Posted May 4, 2015 I was able to get the transmission out today with my dad lending an extra set of arms. I had to remove the exhaust pipe coming down from the manifold to the cat and that extra shifter tunnel floor plate. 3 Quote Link to comment
red13 Posted May 5, 2015 Report Share Posted May 5, 2015 Yea that's kind of the problem. I removed that extra sheetmetal cover that goes around the gear shift hole, I'm gonna try again tomorrow. Also, if your truck is crusty like mine is and you're pulling your transmission, think about doing the u-joints. Yeah I am replacing all that thanks though for the heads up 1 Quote Link to comment
Bleach Posted May 12, 2015 Report Share Posted May 12, 2015 that looks like good welding work 1 Quote Link to comment
SadieD Posted May 21, 2015 Author Report Share Posted May 21, 2015 that looks like good welding work Thanks! I had to weld some new flanges on the exhaust where the cat meets the downpipe, I think I'm improving. The truck's finally off the jack stands now. It's running and driving pretty good. There's a bit of a flat spot in the lower RPM range, I think it's the timing; also the steering is still looser than I like. It should be ready to smog and register now though : ) 1 Quote Link to comment
Charlie69 Posted May 21, 2015 Report Share Posted May 21, 2015 Check your idler arm and the tie rod ends for play. Do not pull the steering gear box apart unless you know what you are doing. The sector shaft in the steering box is timed into the worm. Quote Link to comment
sebpv Posted May 21, 2015 Report Share Posted May 21, 2015 and I did exactly that about a month ago. Now the steering wheel is 180degree loose. The shaft even managed to poke the cover at the bottom when I turned it the other day to remove the tie rods...No choice, Ill have to open it up... 1 Quote Link to comment
SadieD Posted May 22, 2015 Author Report Share Posted May 22, 2015 How do I check for loose? Does it need to be off the ground? Do I just like try to shake it? Suspension/steering is one of my weak areas... 1 Quote Link to comment
Charlie69 Posted May 22, 2015 Report Share Posted May 22, 2015 Find another steering gear box from what you described someone had it apart and did not know how to put it back together correctly. Quote Link to comment
datzenmike Posted May 22, 2015 Report Share Posted May 22, 2015 Loose or incorrectly adjusted wheel bearings, the two ball joints on both the tie rods, the ball joint on the idler arm or the idler arm itself, the ball joint on the pitman arm or the steering box itself, can all have wear and looseness. The 620 has a 19 to one steering box ratio so if all the combined looseness adds up to just 1/4", you will have almost 5" of steering wheel turning with no wheel movement!!! 1 Quote Link to comment
SadieD Posted July 8, 2015 Author Report Share Posted July 8, 2015 Thanks for the advice on the steering/handling, I'll be digging into soon. Today though, the truck passed the smog test! I was a bit nervous, the truck had been sitting in a yard for years when I bought it, I wasn't sure I could make it smog-able. 1 Quote Link to comment
