Turn signal problem on my 620
72MAMBA
  • Replies 1
Not enough info.
So my left turn signal is not flashing but my right is and my emergency lights also come
Does the left light flash with the emergency flasher on? If yes then the wiring to it is fine and the bulb good.
,they worked fine until I unpluged it to check the wires now I plug it and only my reverse comes on when it didn't before?
When you unplugged what? The the emergency flasher, the switch, the rear lights? If it was the plug behind the rear tail light, go back to it and unplug it and check it's clean and making good contact. The fact that the reverse light comes on says you disturbed something causing that problem and caused a new one.
