DatsunSwag22 Posted October 27, 2014 Report Share Posted October 27, 2014 i have a Datsun wagon wit a Ka24e truck motor. i got the Wagon wit the swap done already. didnt have a Gas tank so i put one on. i put gas and after a few mins it started up. idels clean. but when i give it Gas it wants to Die. i cant Figure out why it wont drive. any Info will help. thank you Quote Link to comment
Stoffregen Motorsports Posted October 27, 2014 Report Share Posted October 27, 2014 Low fuel pressure/flow Bad TPS Dirty injectors Clogged fuel filter Could be many things, but I would check those first. Quote Link to comment
mhub91 Posted October 27, 2014 Report Share Posted October 27, 2014 any chance the firing order is wrong? sounds stupid, but it's totally possible. I thought the distributor went one way, but went the other. easyiest way to check is to pull one spark wire from the distributor and see if it bogs or dies down. if the idle is NOT affected by pulling a wire you'll know that's where the problem is. mine would idle and slightly rev, but trying to move it would die. Quote Link to comment
DatsunSwag22 Posted October 27, 2014 Author Report Share Posted October 27, 2014 when i pull wire it Does Bog a lil any chance the firing order is wrong? sounds stupid, but it's totally possible. I thought the distributor went one way, but went the other. easyiest way to check is to pull one spark wire from the distributor and see if it bogs or dies down. if the idle is NOT affected by pulling a wire you'll know that's where the problem is. mine would idle and slightly rev, but trying to move it would die. Quote Link to comment
DatsunSwag22 Posted October 27, 2014 Author Report Share Posted October 27, 2014 it has A new Fuel Pump wit a Fuel Psi gauge. TPS?? How would i Clean the Injectors? Low fuel pressure/flow Bad TPS Dirty injectors Clogged fuel filter Could be many things, but I would check those first. Quote Link to comment
paradime Posted October 27, 2014 Report Share Posted October 27, 2014 Throdle position senser Quote Link to comment
DatsunSwag22 Posted October 27, 2014 Author Report Share Posted October 27, 2014 which is that?? Throdle position senser Quote Link to comment
paradime Posted October 27, 2014 Report Share Posted October 27, 2014 On the throttle (misspelled before) body. It sits at the mouth of the intake manifold. You'll see a wire plugged into it. If it has issues it will be sending wrong, or no information to the ECU when you rev the motor. If you don't have a consult port device, search online and you'll find a diagnostic procedure to text it with a multimeter. Unplug the wire and check resistance between the #1 and #2 terminals. Move the throttle by hand and see if the resistance changes. If so it's good. Quote Link to comment
mhub91 Posted October 27, 2014 Report Share Posted October 27, 2014 To be totally honest, and I'm speaking from experience, KA doesn't usually have TPS issues. Wouldn't waste your time with that until you diag al the simple stuff. Let's start off by checking and Check Engine codes. Go to your ECU. Look on the side where a green and red LED are. See that little screw thing? Turn your ignition to "key on engine off" nowrotate that screw fully clockwise. Wait 2 seconds, rotate fully counter clock wise. The light will start blinking. Count the blinks. One long --- followed by one short - is code 11 Ie., flashes : --- --- --- - - - - - ^ code "35" Please let me know what codes are there. If you are getting a code "35" that is code for "OK". Start here first, and I'm willing to help. Quote Link to comment
paradime Posted October 27, 2014 Report Share Posted October 27, 2014 Listen to the KA guy for sure. I know SRs. Best of luck. 1 Quote Link to comment
DatsunSwag22 Posted October 28, 2014 Author Report Share Posted October 28, 2014 To be totally honest, and I'm speaking from experience, KA doesn't usually have TPS issues. Wouldn't waste your time with that until you diag al the simple stuff. Let's start off by checking and Check Engine codes. Go to your ECU. Look on the side where a green and red LED are. See that little screw thing? Turn your ignition to "key on engine off" nowrotate that screw fully clockwise. Wait 2 seconds, rotate fully counter clock wise. The light will start blinking. Count the blinks. One long --- followed by one short - is code 11 Ie., flashes : --- --- --- - - - - - ^ code "35" Please let me know what codes are there. If you are getting a code "35" that is code for "OK". Start here first, and I'm willing to help. illl let u know in 20 mins Quote Link to comment
mhub91 Posted October 28, 2014 Report Share Posted October 28, 2014 its been 53 mins.... :blush: Quote Link to comment
mhub91 Posted October 28, 2014 Report Share Posted October 28, 2014 Update? Or did you fall asleep in a drunken slumber? :confused: I kid. :rofl: Quote Link to comment
datzenmike Posted October 28, 2014 Report Share Posted October 28, 2014 If someone else did the swap I assume it is still EFI and not converted to carburetor? Quote Link to comment
mhub91 Posted October 28, 2014 Report Share Posted October 28, 2014 He's checking codes, my guess is that it's EFI. .....If not, he'll be searching for codes for a while! EDIT: Oh god, he HAS been gone a while! Quote Link to comment
datzenmike Posted October 28, 2014 Report Share Posted October 28, 2014 Maybe it's taking so long because there is no ECU to find??? Quote Link to comment
datzenmike Posted October 28, 2014 Report Share Posted October 28, 2014 The truck engine almost looks like it has a carb on it. FarmerJoe bolted a plate on the intake with a weber. Quote Link to comment
DatsunSwag22 Posted October 28, 2014 Author Report Share Posted October 28, 2014 He's checking codes, my guess is that it's EFI. .....If not, he'll be searching for codes for a while! EDIT: Oh god, he HAS been gone a while! Sorry about that. i did check n it is 32 like u said. i was doing some welding for a buddy but no Excuses. lol Quote Link to comment
DatsunSwag22 Posted October 28, 2014 Author Report Share Posted October 28, 2014 The truck engine almost looks like it has a carb on it. FarmerJoe bolted a plate on the intake with a weber. how much ? Quote Link to comment
DatsunSwag22 Posted October 28, 2014 Author Report Share Posted October 28, 2014 Maybe it's taking so long because there is no ECU to find??? ECU was Behind the Gauges. so i had to take apart the dash. Quote Link to comment
HRH Posted October 28, 2014 Report Share Posted October 28, 2014 I think it's code "55" for the blinky lights on the '93 D21 ecu, isn't it? Quote Link to comment
paradime Posted October 28, 2014 Report Share Posted October 28, 2014 "If you are getting a code "35" that is code for OK". "i did check n it is 32 like u said." "I think it's code "55" for the blinky lights on the '93 D21 ecu, isn't it?" KA24E Codes: For Pathfinder and hardbody pickups 11 Crankshaft Position Sensor Circuit12 Mass Air Flow Sensor Circuit13 Engine Coolant Temperature Sensor Circuit14 Vehicle Speed Sensor Circuit21 Ignition Signal Missing in Primary Coil31 Engine Control Unit (ECU)33 Oxygen Sensor Circuit41 Air Temperature Sensor Circuit43 Throttle Position Sensor Circuit55 No Malfunctions HRH FTW Come on Datsunswag. This took less than 5 minutes to find with ONE google search. You drive it, you should know this shit. Complete list of Codes for other models:11 Crank Angle Sensor/Camshaft Position Sensor12 Air Flow Meter/Mass Air Flow Sensor13 Engine Coolant Temperature Sensor14 Vehicle Speed Sensor21 Ignition Signal22 Fuel Pump23 Idle Switch24 Throttle Valve Switch25 Idle Speed Control Valve28 Cooling Fan Circuit31 ECU32 EGR Function 33 Heated Oxygen Sensor34 Knock Sensor35 Exhaust Gas Temperature Sensor36 EGR Control-Back Pressure Transducer37 Knock Sensor38 Right hand bank Closed Loop (B2)41 Intake Air Temperature Sensor42 Fuel Temperature Sensor43 Throttle Position Sensor45 Injector Leak47 Crankshaft Position Sensor51 Injector Circuit53 Oxygen Sensor54 A/T Control55 No Malfunction63 No. 6 Cylinder Misfire64 No. 5 Cylinder Misfire65 No. 4 Cylinder Misfire66 No. 3 Cylinder Misfire67 No. 2 Cylinder Misfire68 No. 1 Cylinder Misfire71 Random Misfire72 TWC Function right hand bank73 TWC Function right hand bank76 Fuel Injection System Function right hand bank77 Rear Heated Oxygen Sensor Circuit82 Crankshaft Position Sensor84 A/T Diagnosis Communication Line85 VTC Solenoid Valve Circuit86 Fuel Injection System Function right hand bank87 Canister Control Solenoid Valve Circuit91 Front Heated Oxygen Sensor Heater Circuit right hand bank94 TCC Solenoid Valve95 Crankshaft Position Sensor98 Engine Coolant Temperature Sensor101 Front Heated Oxygen Sensor Heater Circuit right hand bank103 Park/Neutral Position Switch Circuit105 EGR and EGR Canister Control Solenoid Valve Circuit108 Canister Purge Control Valve Circuit Quote Link to comment
Grimlid Posted March 24, 2017 Report Share Posted March 24, 2017 Nice thread guys. Remind me to put my ecu where I can access it to read led codes. Im bookmarking this one. Quote Link to comment
