Sasori my 620 / 240sx headache
AJY
Ok this truck was supposed to be a quick little maintenance daily driver that came with a poorly inserted rotary. So it was then supposed to be an easy KA swap. Turns out there is no trans tunnel (just street signs) and the front of the frame has been hacked up with "suspension mods" (they welded the tie rods together and it has limited adjust-ability for toe)
So I was trying to find a KA and trans that was running ended up buying a 91 240sx with an s14 motor and a half rebuild s14 ka. Now comes the fun part car is almost ready to go to scrap just have to cut the floor roof and rear quarters off. Then I will swap the sub frames and Ka with harness over. Also going to use the 240sx floor pans and trans to patch the 620.
I have a ton of work cut out for me, but as a college student I have a good deal of time on my hands. I have already pulled the motor and dropped it back into a Rx7 and have only had the truck for 2 months by Nov.
Now let's see if I can't patch in some pictures from Fb so I don't have to dink with photo bucket
PO was also from Orlando (I'm now in Austin and found the truck north of Dallas) and my buddy had this photo of the motor from a drift track outing
1458681_708923245823364_3187974770304534
After a four hour drive home
10649732_709678235747865_521542140468413
Next to my 240z
1466273_710316449017377_1767274287811744
CL wheels
10348442_710617665653922_351077728935750
Cleaned up
10703894_711695125546176_597946667710265
Cam with two sets of wheels and half of each set mounted
10649726_711695238879498_313124845954581
After new tires
10433062_711736002208755_898924952585552
These aren't even wide so we will need some body work
10689742_711836122198743_177961899123349
Another motor shot
10599273_712426568806365_891636258990401
Picking up my bar project
1907814_713200688728953_3083715622945278
So the tag wasn't legit and I got caught
10672279_714417185273970_730859425252808
Still haven't mounted these
10671350_716569531725402_457533070519930
Key collection
10426110_717219761660379_824903398395513
Shift boot
10609589_718851358163886_351298475658229
Spare block
10646892_718866751495680_343783674581557
Battery tray
10259703_719239671458388_600511217448297
Donor car
10351389_719645684751120_576640063639692
Stripping
10403458_719750498073972_281886552331833
"new" wire harness
10628235_720081391374216_757760870661959
New motor
1620550_721064501275905_3189930061527954
50$ radio for the road trip to Znationals
10431564_721372261245129_794534558170215
  • Replies 26
Mississippi State line
1625517_722146057834416_8991046974194902
Was too rusty for Znats so I raised hell and parked with my kind I got apologies later
10150784_723415367707485_332499050432869
240z's new motor
10710922_723508017698220_672975083637964
When you have no ac rainx inside and outside of the windows hahaha
10689828_723528397696182_212069736717772
Another state line
1896988_724239920958363_2315823358474275Got home Tuesday night pulled this Wednesday am
Floor pan "trans tunnel' ahhaahah
10616716_724372190945136_486848324945309
Wednesday night
10689858_725942824121406_663546780238900
Motor in and running on the rx7 by that same Sunday
1233978_726756837373338_2364266627038374
Finishing the gut job
this one is out of order hahaha
10417545_978312565517342_772897641701465
Pulling the motor
The 620 has a frame, a real one. The S14 does not. That sub frame is just folded sheet metal and will never mount to the cut 620 frame. Keep the 620 frame and add the S14 engine cross member to it. In addition the S14 strut tops mount to the body sheet metal if you do this with the 620 the first bump the body will tear off the frame. Yu'll need to find some way to tie the top hats to the frame.
The rims are just wrong for a 620. They should have more positive off set to get the tire inside the fender. You can't lower the ride height like that, one good bump and the fender is fucked and cutting and flairs looks like shit. These are better off set...
I imagine that rotary swap moved the steering to the rear of the tires and is R&P now? Otherwise that S14 oil pan won't fit.
Well on looking more I think it has also had a KA in it before since it has already had the cross member shaved down.
I also understand there is no true "frame" to the 240sx, but the front cross member is bolted to the frame rails of the 240sx. If I can successfully shrink that or widen the front of the 620's frame to fit the cross member of the 240sx I should be in good shape. I have yet to do any chopping to the frame I want to make sure I am taking the proper precautions before doing anything permanent.
There are a couple guys on here that have successfully grafted the 240sx suspension into a 620.
There shouldn't be a need to modify the cross member for a KA swap unless it was done with a Frontier KA (which are not as prevalent as the 240 KA).
Cpl620's build
http://community.rat...v8-autox/page-1
Chad Copeland did it first I believe.
http://community.rat...+chad +copeland
There are a few more as well but these two are the furthest along that I know of.
Yeah I was given confidence that it could be done when looking at these two and the way the subframe mounts to the 240sx. It's gonna be a hell of a lot of work either way I go so I might as well go all out right? Right hahaha
Just figured I would give you guys an up date still trying to dump 240sx parts and getting the stuff pulled from the shell. Lots of people asking about it then backing out so after I get back from Florida next week I'll go ham and get this puppy going!!
Yup I bought it from a 17 year old kid who was super annoying and didn't know shit about it who bought it from someone else that couldn't put it back together. So it was doomed hahahaha.
BTW aren't you Stephen? I bought the KA mounts from you, but can't use them since the 620 was all fucked up from the rotary swap. I will say they are great quality though.
In other news I stripped the floor
Soooooo yeah PO was a jack ass fiberglass floor with street signs I had to cut the screws out because they bondo'ed or fiber glassed over them.
Yeah sucked
All out
Sorry it was super bright and potato quality pictures
Well I got the dash out and cleaned up some of the dynamat and shiz. I'm picking up my own engine hoist tomorrow to try and mock the engine up and see where the
shifter hole needs to be before I shave down the tunnel to fit. Still not a bad little bit done before dinner.
Alright update!!!!
So I have been kind of busy, but I got the motor in place mocked on some wooden blocks and measured up the trans tunnel got that sort of mocked in as well.
Then went and scored a air compressor and media blaster full of media!!!!
tested that out last night, going to get a few more parts for it and see if I can get some soda to clean up the floor pans for the new trans tunnel!!!!
And now what you are really here for is pictures (all like 2 of you)
Before the Shave
Cleaned up the garage a for a bit more space
And the welder is on a nice lil cart
Getting the motor in place is not exactly a one man job
So I used straps
She is in I did radius the trans tunnel area a bit since I have to weld it in anyway
Trimmed the trans tunnel down and got her in
Holes line up great
Also with the stock hand brake mounts intact
My CL score all for less than the compressor cost (still had the sticker on it)
And then some of the wonderful Previous owner's work
I'll try and get some more work in this weekend
