620 king cab
  • Please log in to reply
87 replies to this topic
#81 ]2eDeYe
]2eDeYe
    Bastard!
  • User Administrator
  • 18,103 posts
  • Cars:78 620 KC, 77 620 KC, 72 CJ5, 04 G35 coupe mmmm
Posted 11 April 2018 - 06:02 AM
Gonna need to see some pics :)
Smokin' Joe's House of Datto's
Member- *Japanese Trucking Association*
**DATSUN FAQ** ~ If ya know it, post it ~ If ya don't know it, learn it ~
ratsun.net rising sun stickers                     ratsun business cards order thread
620 KA24 Motor Mount Swap Brackets
1977 620 KingCab Deluxe KA24DE Swap - Refresh and cleanup
1978 620 kingcab 4x4 - KA24E SAS w/Dana 44 front and Toyota rear
1967 RL411 Station Wagon
Whenever I think that I'm out of my mind for putting this much time and money into an old Datsun, all I have to do is look some of your threads to know that I'm not nearly as whack as you are.
You're going to skin a few knuckles, stand up too fast and bump your head, hunt around the floor for the nuts and bolts you dropped, invent a few new cuss words and when you're finished you'll say "That wasn't so hard after all!"
#82 gene knight
gene knight
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,733 posts
  • Cars:various datsun toys, vw bug, chevy silverado, mitsubishi outlander,plymouth barracuda fastback
Posted 11 April 2018 - 08:29 PM
i will get some
#83 gene knight
gene knight
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,733 posts
Posted 24 April 2018 - 10:30 PM
so was working on my nephews 620 today with friend carlos from cali and was thinking bed was issue about drive shaft clearance but to find out it is the cab that is the issue, and so the driveshaft that came out of truck is 2 short at the carrier bearing /rubber mount. it s a 2 piece drive shaft so we installed a 1 piece driveshaft and it works but is rubbing on cross member that holds gas tank to frame. the passenger side leans down more than left so i aired up tires to 32 psi and then carlos adjusted passenger torsion bar bolts, i talked with the previous owner to see if he messed with the torsion bars b4, but the only thing he did was install (2) 2 inch lowering blocks on each side of axle/leaf springs so now the bed will have to come off to see if we can tweak the suspension gas tank mounting cross member to get some better driveshaft clearance. also it used to have a L20b and a 5 speed transmission, now it has a L16 with a 4 speed and i think the 5 speed was longer than the 4 speed
#84 ]2eDeYe
]2eDeYe
    Bastard!
  • 18,103 posts
Posted 25 April 2018 - 05:45 AM
Yep, the 4-speed is typically shorter that the 5-speed
#85 datson4life
datson4life
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 3,154 posts
Posted 29 April 2018 - 11:29 PM
Makes me scratch my head for sure as body lines line up but crossmember is in the way of driveline
#86 ]2eDeYe
]2eDeYe
    Bastard!
  • 18,103 posts
Posted 30 April 2018 - 06:54 AM
Is this truck lowered or stock height?
#87 datson4life
datson4life
    Datsun Mechanic
  • Senior Member
  • PipPipPipPipPip
  • 3,154 posts
Posted 30 April 2018 - 08:04 AM
Looks to be lowered
#88 gene knight
gene knight
    Hall Monitor
  • Senior Member
  • PipPipPipPip
  • 1,733 posts
Posted 02 May 2018 - 03:15 PM
going to remove a set of lowering blocks to see if that will free up some space between driveshaft and gas tank x-member behind cab
