Datsun620longbed Posted October 21, 2014 Report Share Posted October 21, 2014 So I recently found out that I need to replace the whole front end of my 620 (king pins and all) was looking at getting a 521 to swap my l20b and 5 speed tranny into and found this. Just wanted to know how hard it would be and get some input and or advice on the idea because after my truck I want another datsun instead of just selling my truck Quote Link to comment
banzai510(hainz) Posted October 21, 2014 Report Share Posted October 21, 2014 a 77 620 still use king pins? a 521 has king pins and like the 521 in the ad most likely needs to be replaced also and they are harder to find Kingpin sets and needs a machine shop to swap them out after you pull the part off the truck. This 521 is a 500 truck in my opinion and youll be going backwards in my opinion think you be better off with the 620 Quote Link to comment
4perrev Posted October 21, 2014 Report Share Posted October 21, 2014 NIce looking 521. The floors don't look too bad and floor board replacement isn't that hard. Swaping the L20b and 5-speed is not hard either. You will need a new shorten'd drive shaft and probably have to fab a transmission mount. There are posts on here about the xmission mount fabs. It all depends on how much time and skills you have to do it. I rescued my 521 but left the 4 speed in it. Body off and it wasn't very difficult. You could search through the builds and see what you might have to do to get her back in shape. Good luck and nice 521 though! Quote Link to comment
EastBay521 Posted October 21, 2014 Report Share Posted October 21, 2014 looks good but I wouldn't want to pay no more than $700 Quote Link to comment
Datsun620longbed Posted October 21, 2014 Author Report Share Posted October 21, 2014 a 77 620 still use king pins?a 521 has king pins and like the 521 in the ad most likely needs to be replaced also and they are harder to find Kingpin sets and needs a machine shop to swap them out after you pull the part off the truck.This 521 is a 500 truck in my opinion and youll be going backwards in my opinionthink you be better off with the 620 Yeah the king pins would be one of the things I'd look at. The only reason I have to replace mine is because the guy who owned it last used what ever to put it together so they're warped and worn. Quote Link to comment
datzenmike Posted October 21, 2014 Report Share Posted October 21, 2014 King pins also just wear out from use. That 521 body is great! so depends on how the body on the 620 is. If close stick with the 620 and fix it up. Like Hainz said... the 521 will likely need pin too. Quote Link to comment
Datsun620longbed Posted October 21, 2014 Author Report Share Posted October 21, 2014 King pins also just wear out from use. That 521 body is great! so depends on how the body on the 620 is. If close stick with the 620 and fix it up. Like Hainz said... the 521 will likely need pin too. Heres my truck with pictures of my king pins. Body is alright but I need entirely new floor pans being as they're currently street signs haha. http://portland.craigslist.org/clc/cto/4725662273.html Quote Link to comment
datzenmike Posted October 21, 2014 Report Share Posted October 21, 2014 http://images.craigslist.org/00S0S_3S6imsH4S0P_600x450.jpg Keep it. Get rid of turbo... it'll never get done and will just blow that motor up. Run with what you know. Quote Link to comment
Datsun620longbed Posted October 21, 2014 Author Report Share Posted October 21, 2014 Okay I'll keep that in mind. How do the king pins look? Quote Link to comment
Datsun620longbed Posted October 21, 2014 Author Report Share Posted October 21, 2014 http://images.craigslist.org/00S0S_3S6imsH4S0P_600x450.jpg Keep it. Get rid of turbo... it'll never get done and will just blow that motor up. Run with what you know. How do the king pins look? And the bolts holdin it together? Or is it too hard to tell? Quote Link to comment
datzenmike Posted October 21, 2014 Report Share Posted October 21, 2014 The wear is inside out of sight. Raise the wheel off the ground and grip the top and bottom of the wheel. Pull out at top and in at bottom then reverse. Place a 2x4 under the tire any pry upward. There should be no up and down play between the king pin parts. There should be virtually no tire movement other than turning side to side. I replaced them in my 521 twice and they were never right. The shop who did the work wasn't very good is my guess. The bushings are 'hammered' in and then have to be exactly reamed to size for the pin with enough room for grease to lube them like a door hinge. There are also selective washer shims to reduce up and down play and a ball bearing and grease fittings that have to line up properly with the bushing so grease can get in. The 521 has the equivalent of casting or 'frost' plugs above and below the pin to seal the ends. I will never have a king pin vehicle ever again. 1 Quote Link to comment
Datsun620longbed Posted October 22, 2014 Author Report Share Posted October 22, 2014 The wear is inside out of sight. Raise the wheel off the ground and grip the top and bottom of the wheel. Pull out at top and in at bottom then reverse. Place a 2x4 under the tire any pry upward. There should be no up and down play between the king pin parts. There should be virtually no tire movement other than turning side to side. I replaced them in my 521 twice and they were never right. The shop who did the work wasn't very good is my guess. The bushings are 'hammered' in and then have to be exactly reamed to size for the pin with enough room for grease to lube them like a door hinge. There are also selective washer shims to reduce up and down play and a ball bearing and grease fittings that have to line up properly with the bushing so grease can get in. The 521 has the equivalent of casting or 'frost' plugs above and below the pin to seal the ends. I will never have a king pin vehicle ever again. Are there any alternatives to the king pins that is worth it or is that a stupid idea and question? Haha Quote Link to comment
uberkevin Posted October 22, 2014 Report Share Posted October 22, 2014 Ball joint mod.. but then your spending some dough. Quote Link to comment
Datsun620longbed Posted October 22, 2014 Author Report Share Posted October 22, 2014 Ball joint mod.. but then your spending some dough. How much dough are we talking? Quote Link to comment
uberkevin Posted October 22, 2014 Report Share Posted October 22, 2014 I'm not to sure on full cost but I know it's a lot of work. Here's one way. http://community.ratsun.net/topic/17408-johny5s-521/page-2 I know there's a member on here that sells custom ball joint stuff. Maaaay be on ebay. Quote Link to comment
wayno Posted October 22, 2014 Report Share Posted October 22, 2014 This is the right/correct way to do it, lot of work though, and you need to know how to weld/grind. I'm not to sure on full cost but I know it's a lot of work.Here's one way. http://community.ratsun.net/topic/17408-johny5s-521/page-2I know there's a member on here that sells custom ball joint stuff. Maaaay be on ebay. Quote Link to comment
Datsun620longbed Posted October 22, 2014 Author Report Share Posted October 22, 2014 Here's kind of what I think needs to be replace. hard to get a pic to show it but let me know what you see. Quote Link to comment
wayno Posted October 22, 2014 Report Share Posted October 22, 2014 What I see is a kingpin suspension, you want to replace all of it? Quote Link to comment
Datsun620longbed Posted October 22, 2014 Author Report Share Posted October 22, 2014 That is what I was told to do but I'm unsure on that's what needs to be done because look here. it doesn't look right to me. Sorry I don't really understand the king pin setup because this is the first time I've seen it and this is my first vehicle. Quote Link to comment
wayno Posted October 22, 2014 Report Share Posted October 22, 2014 OK, actually your right, I didn't see it before, someone has put a bolt in there where the lower spindle is supposed to be, that is scary. See the photo below you posted, that is clearly a bolt in there. Your supposed to have something that looks like this in the photo below, it has a custom lower arm with disc brakes, don't look at that, just look at the spindle connection with the grease fitting on the end of it. You need to buy and install the proper parts if it is possible anymore, it could be ruined, I would have to see it to tell you for sure. That is what I was told to do but I'm unsure on that's what needs to be done because look here. it doesn't look right to me. Sorry I don't really understand the king pin setup because this is the first time I've seen it and this is my first vehicle. Quote Link to comment
mklotz70 Posted October 22, 2014 Report Share Posted October 22, 2014 Look a bit closer guys. The PO did a dogbone flip. The fulcrum pins are there, but they're on the UCA. LOL!! Not good!! Quote Link to comment
wayno Posted October 22, 2014 Report Share Posted October 22, 2014 Look a bit closer guys. The PO did a dogbone flip. The fulcrum pins are there, but they're on the UCA. LOL!! Not good!! Wow, I didn't even know that was possible, I guess I should shut up, I don't even see what I am seeing. The only vehicles I have with this equipment left are 320s, and they are all done, I don't have to worry about them again. Quote Link to comment
mklotz70 Posted October 22, 2014 Report Share Posted October 22, 2014 It's not possible....at least not safely. You saw the bolt at the bottom.....I just happened to see the fulcrum pin at the top.....took me a min or two to realize what I was looking at. The UCA's must have been drilled out to fit the bigger pins. The entire weight of the front end is on those two bolts. I can't believe the person that did this trusted the upper arms to hold the pin without the end caps on them. I think it's fairly salvageable, but won't know unless it's torn down to see just how much damage has been done. Quote Link to comment
denmarkboy Posted October 22, 2014 Report Share Posted October 22, 2014 How much dough are we talking? I still have the entire front suspension I offer you for 150.00 , you could easily swap everything in a weekend easy . Someone clearly screwed that suspension up, that's not safe at all . Quote Link to comment
banzai510(hainz) Posted October 22, 2014 Report Share Posted October 22, 2014 wELL IF THIS IS YOUR TRUCK IN THE AD AND ITS YOUR AD, I love this truck but being a senior in high school I neither have the time nor the money for it. Then most likely you dont need to buy old cars in general or Datsuns. As the 521 needs alot of work also and you just explain your situation in the ad. Then as Mike pointed out about the flip it reaaly should get fixed ASAP and i you dont have money to this this I assume. Denmark boy could sell the front suspension for less as Im sure there are not to many people really needing them.But hate to sell it for cheap then you only sell it a few days later anyways(common here) Quote Link to comment
