Low power in KA24E
kunsx
Just got my "new" engine started in my 521 pick up and was a bit dissapointed since the power only was around 100hk in the dyno bench. The engine is from a truck but I have replaced the inlet manifold with one from a Nissan Prairie. There is KMS engine management system and is tuned in a dyno bench. There is a few things I think of myself,
1: To small exhaust- only 2" so get that rebuild to 2,5"
2: Myabe my O2 sensor is not working right or temp sensor- to be checked out.
3: I have the complete cylinder head of the Prairie engine- get that one ported and planed 1-2mm and replace.
Any ideas is much apreciated.
  • Replies 4
1/ Two inch is plenty for an unmodified engine.
2/ O2 sensor is only used by the ECU during part throttle and when engine is warmed up. Full throttle I believe forces the ECU to revert back to a stored air/fuel map that is much richer for better performance and not for economy. I may not be explaining this properly but this is close. Could the TPS (throttle position sensor) not be signaling that you are at full throttle?
3/ If this is something else out of adjustment, a ported head will be an expensive disappointment.
