mrpizzly Posted October 18, 2014 Report Share Posted October 18, 2014 I'm trying to replace the slave cylinder in my Datsun 720 2wd and after bleeding it I tighten it all up and push the clutch and the slave rod gets forced toward the clutch fork and pops all the fluid and then obviously stops woking. I noticed my clutch fork gets pushed further than the rod goes and I can move it back and forth with my fingers help please Quote Link to comment
mrpizzly Posted October 18, 2014 Author Report Share Posted October 18, 2014 Here is a pic http://imgur.com/1I1GMLE Quote Link to comment
john510 Posted October 18, 2014 Report Share Posted October 18, 2014 Does the new slave have the same length rod as the old one ? maybe the slave was not the problem and its the clutch that might be bad ? 1 Quote Link to comment
mrpizzly Posted October 18, 2014 Author Report Share Posted October 18, 2014 Does the new slave have the same length rod as the old one ? maybe the slave was not the problem and its the clutch that might be bad ? So the clutch fork has no tension/ resistance on it so I know now it was most likely not the slave because everything is the same rod length and whatnot. So if it is a problem with my clutch fork not having pressure on it does that mean it is a issue inside the housing? If so how and what should I do to check it Quote Link to comment
DanielC Posted October 18, 2014 Report Share Posted October 18, 2014 "So if it is a problem with my clutch fork not having pressure on it does that mean it is a issue inside the housing? If so how and what should I do to check it" Good possibility you have a problem in side. Your choice, pull the engine, and leave the transmission in the truck, pull the transmission, and leave the engine in place, or pull both together, and then tale the two apart, and look at it. Quote Link to comment
datzenmike Posted October 18, 2014 Report Share Posted October 18, 2014 I'm trying to replace the slave cylinder in my Datsun 720 2wd and after bleeding it I tighten it all up and push the clutch and the slave rod gets forced toward the clutch fork and pops all the fluid and then obviously stops woking. I noticed my clutch fork gets pushed further than the rod goes and I can move it back and forth with my fingers help please More background info needed. What happened recently that you replaced the clutch slave??????? Quote Link to comment
wayno Posted October 19, 2014 Report Share Posted October 19, 2014 Did you just put the transmission in, or did you change the slave because you thought that was the issue? Quote Link to comment
mklotz70 Posted October 19, 2014 Report Share Posted October 19, 2014 The fork looks like it's too far back in the hole to start with. It should be more straight out to begin with. That's about where it should end up when pushed. I'd be looking at the fork and throwout bearing to see if they're hung up. Is the rear up on jack stands? You might start the engine and see if it will go in gear.......don't push the clutch pedal. If it slips into gear with the motor running, then your clutch is disengaged......something's holding it in. Quote Link to comment
wayno Posted October 19, 2014 Report Share Posted October 19, 2014 The fork looks like it's too far back in the hole to start with. It should be more straight out to begin with. That's about where it should end up when pushed. I'd be looking at the fork and throwout bearing to see if they're hung up. Is the rear up on jack stands? You might start the engine and see if it will go in gear.......don't push the clutch pedal. If it slips into gear with the motor running, then your clutch is disengaged......something's holding it in. I thought the same thing, that's why I asked if the tranny had been just been put in, if nothing is broken, it must have the wrong collar in it. He might be able to make a longer rod, but it is not a for sure cure, need to know if the tranny has been out. Quote Link to comment
datzenmike Posted October 19, 2014 Report Share Posted October 19, 2014 Collar could have slipped off the end of the fork. It's only clipped on and easily dislodged. Fork is now along side or forward of the collar and why it appears the slave end is so far back.. Quote Link to comment
wayno Posted October 20, 2014 Report Share Posted October 20, 2014 My money is on either the transmission was changed and the wrong collar was used, or something destroyed it's self inside the bellhousing. I just went out and pulled and twisted on a transmission/clutch arm I have connected to a diesel engine, I could not get it off the ball because the trans. case was in the way, pulled fairly hard too, I could not dislodge the arm from the throwout bearing collar either, as the hole for the clutch arm is not big enough to remove the arm from the ball, it binds. I did not use vice grips though, but it would seem like if the engine/transmission were never removed, one would not be down there with vice grips pulling/twisting on that arm. Quote Link to comment
datzenmike Posted October 20, 2014 Report Share Posted October 20, 2014 I have to agree when the trans is seated properly it's pretty much impossible to dislodge but easily done when mating them together. Quote Link to comment
banzai510(hainz) Posted October 23, 2014 Report Share Posted October 23, 2014 what is that to the right insdie the square hole? if this wiggles around(fork) by hand then trans needs to be pulled. maybe clutch fingers broke? Quote Link to comment
Nuclear Water Boy Posted October 24, 2014 Report Share Posted October 24, 2014 Clutch finger is a possibility or the arms pivot broke. But I like the "Wrong T/O bearing carrier. But we still need to know if the trans was removed and if so what was done? What ever the reason that trans is looking like it need to come out a simple 2 beer job. Quote Link to comment
