Dalesun Posted October 16, 2014 Report Share Posted October 16, 2014 I have some play in my king pins. Instead of replacing them I though about just swapping 620 dog bones on there. To me it would be easier than replacing king pins. Found a thread from back in 07 but the guy never posted if it worked out or not. Want to know if this can be done and if anyone has done it before. Quote Link to comment
flatcat19 Posted October 16, 2014 Report Share Posted October 16, 2014 To do that, you're taking the king pins out, and would still have slop. King pin kit, $30 on eBay. $80 for machine shop to ream the bushings. 3 or 4 hours of your own labor. That's if they even swap over. I think k the earliest of 620s was the same size as a 521. All the rest are different. Contact mklotz. He has talked about this a lot. Quote Link to comment
datzenmike Posted October 17, 2014 Report Share Posted October 17, 2014 Keith, I get the same part number for the pin the bearing and the upper and lower bushings for all 620s through '77. Unfortunately it does not look like the 521s are the same. Quote Link to comment
flatcat19 Posted October 17, 2014 Report Share Posted October 17, 2014 I tried to write something close to that. I knew that for the most part there was a difference between 620 and 521 pins. Quote Link to comment
Dalesun Posted October 17, 2014 Author Report Share Posted October 17, 2014 Was wanting to swap over everything atached to the 620 dogbone. King pins, hub, bearing, brakes. I know the wheel cylinders are metric and would need adapters. I have a pair from a 72 620 and it would be for my 71 521. Just wanting to know if the 620 dogbones would bolt into the 521 upper and lower control arms. Or if the 620 upper and lowers will bolt onto the 521 frame so I wouldnt have to deal with the lower fluction pins. Ive ordered that ebay kit from Singapore and they came with rust on them that was more than just surface rust. Quote Link to comment
