LUIS COLCHETE Posted October 16, 2014 Report Share Posted October 16, 2014 Hi! Im rebuilding a Datsun A12 Engine with some new parts (main bearings and rod bearings, piston rings, water and fuel pump, chain, tensiometer all gaskets) and some used parts but in great conditions: flat top pistons (i think are unmarked conecting rods. (i think are unmarked?) I want to know if i can change the positions on motor. Change the position of conecting rods and pistons on Engine. 1st with 2nd, 3rd with 4th and etc. I think i can change the position of piston because i will put in it new rings as wll the conecting rods. What do you think? I counting with your experiences. Many thanks on advance. Luis PS In my mind the only thiing i cant change is the main bearing caps. It is correct what i said? Quote Link to comment
datsunaholic Posted October 16, 2014 Report Share Posted October 16, 2014 Why? Always best to put parts back where they came from. Bores aren't perfect, so pistons are sometimes matched to each cylinder based on the +/- imperfections. And weight balanced for the rod/piston combo. The rods will be marked unless aftermarket. Quote Link to comment
Mattndew76 Posted October 16, 2014 Report Share Posted October 16, 2014 Mark them as you take the engine down. Same with the push rods for the valves. Quote Link to comment
LUIS COLCHETE Posted October 16, 2014 Author Report Share Posted October 16, 2014 Hi! I know.... the marks are important... but.. Quote Link to comment
KELMO Posted October 18, 2014 Report Share Posted October 18, 2014 I second the motion to put them back where they came out of, IE, pistons, rods, push rods. Quote Link to comment
LUIS COLCHETE Posted October 18, 2014 Author Report Share Posted October 18, 2014 Hi! My car has an original engine that i want disamble..... I want build one... with some performance parts that i bought... Better intake, twin carbs, exhahust, better cam but my problem is: I have used flat top pistons and conecting rods with few kms to put in a diferent block engine in excelent conditions.... I dont know which is the first piston or second? As well the conecting rods..... The clearences are perfect....... I dont what are the sequences of 1, 2 , 3 or 4 Thanks Luis Quote Link to comment
datzenmike Posted October 18, 2014 Report Share Posted October 18, 2014 Datsun cranks are balanced separately. All the individual pistons and rods with caps also. You should be able to run any rod in any position but only if the rod is matched with the proper rod cap. 1/1, 2/2, 3/3 or 4/4. I'm building an LZ engine and have access to a scientific balance. It's so sensitive that a breeze blowing in the window disturbs the readings. The KA pistons were all withing a few grams... I found the lightest and removed metal to make the others all within 1/10 gram. The individual rods and caps are close to the same weight within 4-5 grams BUT caps and rods are different individually and only weigh close to the same when matched 1/1 2/2 and so on. I suggest keeping them together as sets. Replacement pistons and rods are available and nowhere does it say to balance them so you should be able to replace a broken one with confidence that the balance is not upset. Quote Link to comment
LUIS COLCHETE Posted October 18, 2014 Author Report Share Posted October 18, 2014 Hi Many thanks The only thing i cant change is the main bearing caps.... My block has the main bearing caps in the correct sequence Quote Link to comment
LUIS COLCHETE Posted October 26, 2014 Author Report Share Posted October 26, 2014 Hi! As i sayng im pretending to mount used but in good shape: conecting rods with respective caps and pistons (I know i have to install pistons in cylinders with stamped number of piston to head toward front of engine) in a diferent but in a good A12 Block with a difrent crankshaft. It is a cocktail....... What do you think? My block has the main bearing caps in the correct sequence (i think is the most important, without them is garbage)?????? Luis Quote Link to comment
datzenmike Posted October 27, 2014 Report Share Posted October 27, 2014 The caps should be kept in sequence, yes. The factory bolts them down and align bores them so they are straight and line up with the crank. Quote Link to comment
LUIS COLCHETE Posted October 27, 2014 Author Report Share Posted October 27, 2014 Many Thanks King Rat Quote Link to comment
