spec-bre Posted October 14, 2014 Author Report Share Posted October 14, 2014 That's some rough ass port work! Use one of these to clean her up a bit... ;) That was the rough in Joel. I forgot to take the additional finish work. Quote Link to comment
Just Joel Posted October 14, 2014 Report Share Posted October 14, 2014 Right on :) 1 Quote Link to comment
WooHooMobile Posted October 16, 2014 Report Share Posted October 16, 2014 Looks like a great score... but you already know that. B) 1 Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 While the engine is out I wanted to address the front suspension updates and upgrades. All new Moog ball joints and Rod ends were added Experimental engineering TC rod end kit 1" front sway KYB's David Carrols pitman arm kit The modified 510 struts were swapped out for ZX units using the same GC sleeve kit and 250lbs eibach springs Datsun parts outlet slotted ZX rotors Relieved/clearanced ZX stock calipers and brackets 3/8" spacers to aid in any possible clearance issues New Timken sealed bearings Lower LCA camber bushings to aid in 7" 0 offset wheel clearance (note: I have had zero of the rumored issues I have been warned about with these camber bushings) GC SX camber plates up top Cusco Strut tower brace Steering box brace I believe that's all the upfront updates. Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 3/4 " bump steer spacers! Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 The visible differences of the ZX upgrade from 510 struts. Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 Pitman arm insert Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 Front end buttoned up 1 Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 Now on to the rear Addco rear anti roll bar Late 60's camero shocks Started with 1.5 blocks with a 5 deg bevel but I have stepped down to 2" same bevel. Might go another 1/2 in the future All new wheel cylinders Drum brake hardware kits Porterfield R4S brake shoes Still need to make a set of bushings/inserts for the leafs to do away with the 40+ year old rubber Quote Link to comment
mrbigtanker Posted October 16, 2014 Report Share Posted October 16, 2014 Looking good.the back is lowered 2" you say. Quote Link to comment
spec-bre Posted October 16, 2014 Author Report Share Posted October 16, 2014 This is with the 2" blocs in the rear. Quote Link to comment
shacks510 Posted October 17, 2014 Report Share Posted October 17, 2014 I wish I had a big indoor space to work in. 1 Quote Link to comment
4perrev Posted October 17, 2014 Report Share Posted October 17, 2014 Nice score! Good work and she looks awesome thus far. Liking the Su carbs. Quote Link to comment
banzai510(hainz) Posted October 17, 2014 Report Share Posted October 17, 2014 IM impressed!!!!!!!!! I like 15inch wheels myself this makes me want a wagoon to save 1 Quote Link to comment
spec-bre Posted October 22, 2014 Author Report Share Posted October 22, 2014 More new bits. Door seals and window channel. Speed daddy alum Rad and fans Nos fuel pump Alt tinsioner Factory Tach Gauges Quote Link to comment
spec-bre Posted October 22, 2014 Author Report Share Posted October 22, 2014 I forgot to really document/photo the engine install but it went without any hitches. Matchbox conversion Quote Link to comment
banzai510(hainz) Posted October 22, 2014 Report Share Posted October 22, 2014 Is that a Chinese Rad(CHAMPION BRAND)? you use spacers on the rad suport to push it back abit? PEOPLE SAY THEY LEAK BRAND NEW. i GOT ONE BUT HAVENT RAN IT. Quote Link to comment
spec-bre Posted October 22, 2014 Author Report Share Posted October 22, 2014 Is that a Chinese Rad(CHAMPION BRAND)? you use spacers on the rad suport to push it back abit?PEOPLE SAY THEY LEAK BRAND NEW. i GOT ONE BUT HAVENT RAN IT. It's a "Speed Daddy" eBay unit. No issues to date. Yes I had to space it out but I like the unit. Quote Link to comment
banzai510(hainz) Posted October 22, 2014 Report Share Posted October 22, 2014 Thanks Im sure its a Chinese made unit then sold thru speeddaddy. Makes me want to put mine in Quote Link to comment
spec-bre Posted October 22, 2014 Author Report Share Posted October 22, 2014 The old gal will lift the inside rear skin up on a hard turn!! 2 Quote Link to comment
4perrev Posted October 26, 2014 Report Share Posted October 26, 2014 That ol' Betty is looking good! Like the track day photo! Quote Link to comment
