Nistune and Wideband Connection
PoorMtnKid
Anyone on here have experience tuning with Nistune and also getting an AEM Uego Wideband connected to the computer. Right now I have all the hardware for it to connect to the computer however when I go to test it to make sure it gets the proper readings as the Widebands manual says I get nothing but 0's. Also I just installed STI yellow injectors and a Z32 maf on my SR20DET, when I go to start the car it fires up but quickly dies out due to excessive fuel. I adjust the injectors and maf in the tune and tried to mess with the latency but got no luck.
Any help would be great.
  • Replies 3
Do you know what size the injectors are, ie., 270cc, 550cc, etc.?
I had problems getting my AEM UEGO to hook up as well.  I found that I can only plug it into 2 of the 3 USB ports in my laptop.  Also, go into configuration and set up the wideband sensor.   I have mine set to "AEM UEGO"  "PORT: NONE"  and auto search.
  • 2 months later...
