DatMo Posted October 11, 2014 Report Share Posted October 11, 2014 So I've been doing research because I'm planning to buy a new clutch but I cannot find what this clutch came off of and it was on a 5spd that I can't seem to figure out either. What i do know is that is from apmco and i believe the cover plate is 30210 and the clutch has 30100e4301 u stamped on it. Thanks in advance. Quote Link to comment
datzenmike Posted October 11, 2014 Report Share Posted October 11, 2014 Clutches and transmission have zero bearing on each other. 30210 is only the first 5 numbers of the part and simply says it is a pressure plate. Look beside these for the other 5. 30100-E4301 is a '75 and up 225mm clutch disc that is also used on the... L20B and Z22 720 truck The L24E in the 810 The '82-'83 S110 200sx Z22E and the 240/260 Z car Quote Link to comment
DatMo Posted October 11, 2014 Author Report Share Posted October 11, 2014 Clutches and transmission have zero bearing on each other. 30210 is only the first 5 numbers of the part and simply says it is a pressure plate. Look beside these for the other 5. 30100-E4301 is a '75 and up 225mm clutch disc that is also used on the... L20B and Z22 720 truck The L24E in the 810 The '82-'83 S110 200sx Z22E and the 240/260 Z car Perfect, I got a stage 2 clutch off a 240z that should switch right on then. Haha thanks Quote Link to comment
banzai510(hainz) Posted October 11, 2014 Report Share Posted October 11, 2014 I would bet the pressure plate on the ground and measure the center clutch fingers to make sure they the same height this deterimines the to/bearing color lentgh as my book stated I think the 240z(225mm) clutch might had 2 sizes but different years 1 Quote Link to comment
datzenmike Posted October 11, 2014 Report Share Posted October 11, 2014 If a 240z PP, then 30501-U0200 is the matching collar.... total length without bearing is 42.5mm Quote Link to comment
DatMo Posted October 12, 2014 Author Report Share Posted October 12, 2014 If a 240z PP, then 30501-U0200 is the matching collar.... total length without bearing is 42.5mm I'll check as soon as i get my clutch, it's not home but I'll see if they have part numbers on it. I don't recall seeing anything but it is an exedy clutch. Quote Link to comment
datzenmike Posted October 12, 2014 Report Share Posted October 12, 2014 The Exedy part numbers won't likely match the Nissan numbers... you'll have to check with Exedy. Also the clutch disc thickness will affect the overall collar length I imagine. Best fit would be the Exedy clutch, PP and collar as a bought set. Quote Link to comment
