l18 timing cover woes
cr83
hi i am regasketing my l18 and upon inspection of the timing cover i noticed that the oil pump drive is wearing into the timing cover towards the distributor, has anyone else ran into this? i am going to try using copper shims on the drive shaft in the worn area to put it back into position as seen in the pic. is there a different fix for this problem? thanks
  • Replies 1
Can't see how the spindle is moving upwards when it is already up against the bottom of the distributor, or should be. This is the first time I have heard of this happening.  Make sure the spindle isn't jammed down into the oil pump drive.
