Bike trials Posted October 1, 2014 Report Share Posted October 1, 2014 So first off, love this forum, an its been awhile since ive been on here having sold my 73 620 two years ago. But Datsun's are definitely an addiction of mine, so i just recently purchased another. need to get the neutral safety switch bypassed to get it out on the road. Quote Link to comment
Bike trials Posted October 1, 2014 Author Report Share Posted October 1, 2014 I'm currently wrapping up a manual to auto swap on a 210 that was started by the previous owner (blownb310), now everything is in place but i need to tie up the neutral safety switch in order to get her to turn over.... and that's where i have run into an issue. i have the portion of the harness that should have run to the old automatic transmission, but i am unsure which wires need to be bridged. i have both a 79 and 80 shop manual that have both proved useless thus far. i have a picture of the harness but am unable to upload it Quote Link to comment
datzenmike Posted October 1, 2014 Report Share Posted October 1, 2014 I'm currently wrapping up a manual to auto swap on a 210 that was started by the previous owner (blownb310), now everything is in place but i need to tie up the neutral safety switch in order to get her to turn over.... and that's where i have run into an issue. i have the portion of the harness that should have run to the old automatic transmission, but i am unsure which wires need to be bridged. i have both a 79 and 80 shop manual that have both proved useless thus far. i have a picture of the harness but am unable to upload it I think you mean the other way round. The automatic has a switch that only allow the starter to operate in PARK and NEUTRAL. It also contains the back up lamp switch. Usually the back up switch wires are both Red/Black stripe and the interlock wires are White/Black and Black/White. Yours may be different but if you can isolate the back up lamps then the other pair must be the interlock. Just join together... securely. Preferably soldered and covered with heat shrink tubing. You don't want this to corrode and break and leave you stranded somewhere. Quote Link to comment
Bike trials Posted October 1, 2014 Author Report Share Posted October 1, 2014 yeah my bad, auto to manual. this is what i believe to be the former auto transmission harness, traced the reverse lamps to a green/red and a red/black from what i remember last night. Im also rather confused by what the last 3 wires are on this harness? perhaps i have the wrong on but i don't believe so? Quote Link to comment
Bike trials Posted October 1, 2014 Author Report Share Posted October 1, 2014 still unable to post the picture? Quote Link to comment
Bike trials Posted October 11, 2014 Author Report Share Posted October 11, 2014 so i figured out the wires via an online, had to replace the starter because it was worn ( never buy a duralast starter for the A series, i had t grind it down a bunch to clear the block) okay so getting to my point, she turns over really well now, but wont start for me, its really cold here so i didn't know if there was any tips/tricks for first start in cold on a carbed car? tried starter fluid, pumping the gas... she wants to start but wont stay running... if it helps i have duel side draft dellortos and open header right now, havent gotten the exhuast on yet. thankyou Quote Link to comment
Rays74 Posted November 6, 2014 Report Share Posted November 6, 2014 I'm not real familiar with the Del's but I would start with getting the choke(s) to richen up.......sounds like it's just starving for fuel when cold :D --Ray Quote Link to comment
