DATSUN671 Posted September 29, 2014 Report Share Posted September 29, 2014 Is it possible to take out the outer Venturi without removing the carb from the motor? Quote Link to comment
banzai510(hainz) Posted September 29, 2014 Report Share Posted September 29, 2014 why would you do this? I have done a inner venturi . you COULD RUIN THE CARB AS ITS A CHEAP POP METAL TYPE SET UP. as I did Quote Link to comment
Stoffregen Motorsports Posted October 1, 2014 Report Share Posted October 1, 2014 Yes it is possible. There is a set screw on the underside the carb. The venturi (in the middle) is commonly referred to as the venturi. The outer (large hole) venturi is simply referred to as a choke. ie- 44 PHH Mikuni with 38mm chokes. Quote Link to comment
