DatsunKing2014 Posted September 28, 2014 Report Share Posted September 28, 2014 Ok I need some help guys I think I cracked the cylinder head on my truck. Im new to the forum but nobody knows about datsuns in oklahoma atleast not ne ok so I am wandering if I can put the ka24de motor and tranny in my truck without a lot of problems the 24 is fuel injected my z22 is carberated. Also how do I post pics of my truck Quote Link to comment
WI 720 Posted September 28, 2014 Report Share Posted September 28, 2014 Thanks for posting. You can upload your photos to photobucket or some other site and then link using the button that looks like a smal picure of a tree to post the link. it is next to the <> link. There is icon that looks like a switch in the upper right hand corner of the rich text tool bar. You may need to turn that on. Hopefully that helps. Maybe someone else can clarify. Quote Link to comment
flatcat19 Posted September 29, 2014 Report Share Posted September 29, 2014 Use photo bucket. Load photos. C/P the IMG code to here. That easy. The KA will fit-yet not a bolt-in and go kinda deal. Lots of the info is on the forum though. Have fun reading. See you in a few months. Quote Link to comment
DatsunKing2014 Posted September 29, 2014 Author Report Share Posted September 29, 2014 Thanks alot guys will get some pics soon still not sure if im gonna do the swap though Quote Link to comment
Fat510 Posted September 29, 2014 Report Share Posted September 29, 2014 Just swap the cracked head off for a good one and you'll be fine. Going fuel injected isn't as easy or quick as it sounds Quote Link to comment
datzenmike Posted September 29, 2014 Report Share Posted September 29, 2014 Pull the head off and inspect. What makes you think the head is cracked? This is very unlikely unless the block froze last winter. Simplest answer is a blown head gasket. Quote Link to comment
DatsunKing2014 Posted October 1, 2014 Author Report Share Posted October 1, 2014 Well I pulled it off and found the head warped. So I took it to a machine shop he shaved it down and now im waitin on the gasket and shim. Ill post pics. I could actually buy a ka24de cheaper tan a nee head is why I asked aboit the swap thanks guys Quote Link to comment
DatsunKing2014 Posted October 1, 2014 Author Report Share Posted October 1, 2014 1 Quote Link to comment
flatcat19 Posted October 1, 2014 Report Share Posted October 1, 2014 Do you have any junkyards near you? Z24s should be a plenty out there. Maybe plan out a KA24E head swap with some R1 carbs. 1 Quote Link to comment
datzenmike Posted October 1, 2014 Report Share Posted October 1, 2014 Well I pulled it off and found the head warped. So I took it to a machine shop he shaved it down and now im waitin on the gasket and shim. Ill post pics. I could actually buy a ka24de cheaper tan a nee head is why I asked aboit the swap thanks guys No you can't. The KA swap is not that cheap. Needs high pressure fuel pump for the EFI, total wiring change over for EFI, engine mounts plus an oil pan that will clear your front differential, exhaust hook up. Quote Link to comment
DatsunKing2014 Posted October 1, 2014 Author Report Share Posted October 1, 2014 Ok thanks mike im probably just gonna put it back together and hope it works out just waitin on the head gasket to come in Quote Link to comment
DatsunKing2014 Posted October 1, 2014 Author Report Share Posted October 1, 2014 Plenty of junkyards but cant find one with any parts that will work datsuns are pretty rare here I guess Quote Link to comment
]2eDeYe Posted October 1, 2014 Report Share Posted October 1, 2014 If you do eventually want to swap to a KA, look at using a truck block for better oil pan clearance. Quote Link to comment
