My first 1973 1200
DTSUN73
  • Replies 59
Where did you land those tires? I have looked without any luck.
Do you have a link?
Your car is looking great.
I had do research myself on sizes available and then request them from Americas Discount Tires.   I have a brother in-law that manages one so maybe there was a little more patience on just a random guy asking a lot of option requests over the phone...  He then researched who had it in stock and shipped it to a local store, which I believe is normal by request.
175/50/13 Nankang As-1
Before I did the front and rear swaps, I had just the fronts replaced so they didn't rub with kumihimo tires 155/70r13
I only have 5.5 wide rims to there isn't any stretch on either.
Ah yes, the old brother works in a tire shop bit.
I had Sumitomo 175/50/13's on my 1200 but sold them with my old wheels. They have appeared to stop importing them.
Moved over to 185/60/13's .
Now want them back,,, maybe. I do like having some sidewall Cush as well not feeling every small road defect not to mention the reflectors that become gigantic obstacles . Sometimes form has to put function in the back seat.
We will see how much lower I can get the front after cutting down the strut tubes and then decide.
  • 9 months later...
So my car was down for about 6 months while the whole wiring harness was being worked on.  Then I got the whole transmission rebuilt and the ujoint replaced.  She's going good now, driving to work everyday again!
11922891_10206009103041332_6227964022187
11947778_10206009103121334_4659283717152
I finally put on the front bumper that I purchased.
11950378_10206009053000081_8578353497522
11952855_10206009054800126_9034883660927
I also removed the damaged Bumper Guard off the back. Not sure if I like it yet so bare, unprotected...
11947879_10206009052920079_4805139581978
11947877_10206009052960080_2901211838778
if you don't mind me asking... how much did you paid for the entire setup?  also I'm in need of a re wire.. any pointers or place to buy it new..
thanks in advance!
As in from the start until today?
$2000 as is when purchased from Reno. Hardly running
+$8000ish in front suspension parts, bushings, tires, transmission rebuild, new clutch, wire work and countless misc small parts.
I had taken my car in to Fitted Garage for the wire harness clean up, the entire engine harness looked liked it was twisted together in a million spots...
I should have being more specific, the T3 parts, my harness was chew by some rats or quitters
I understand...I over paid for mine..4800 plus new 4 tires , brake and clutch pump and misc parts and still not running.. need engine work and probably new clutch
by the way your car looks bichin!!!!
The more I look these days, I really got a good deal...
T3 sells a Datsun 1200 set up like their 510 conversion, it's just not listed on the website.  I called and chatted with them a little for some parts.  Here is a link to the 510 set up, the difference would be 1200 struts vs the 280zx. https://technotoytuning.com/nissan/510/front-coilover-conversion-datsun-510-280zx-strut-casings
Just as a side note, if you swap in the lower control arms, TC rods, outer tie rods, and steering knuckles from a 79-82 210 (all straight bolt-in), then you can use the 280ZX struts and brakes, and thus any strut/brake upgrades for a 510/280ZX.
Ill be looking for the parts numbers, sound a good way to improve braking
God I wish I knew this before, I just replaced my whole front end but I haven't upgraded my brakes yet.  Do you know if the 280zx knuckles allow more room for wider rims?  I bought a set of 13x8 and there's no room to turn unless I install spacers.
Mklotz has in the past made a kit to upgrade the brakes on the 1200, retaining the light and sufficient strut housings but adding larger disc and calipers but also fitting most 14" wheels.
I have one of the kits but have not installed it.
I currently use 13" wheels and feel as if the brakes are more than adequate for daily use.
There is a right up on here somewhere about it.
Morrison maybe.?
I would be looking for a 210 in the junkyard. It would cost a fortune to buy this all new.   ^_^
Yes, they should. It narrows your track width about 1/2" per side, so it will turn easier with less chance of clipping the fenders or rubbing the footwells.
And what 13s? Most don't fit over 280ZX brakes.
Also, not 280ZX knuckles. You need 210 LCAs, steering knuckles, outer tie rods and TC rods. Then get 280ZX struts/brakes.
What do you think is on my 1200 right now?   :P
But that was for ease of install, and because A15. Were I running a bigger engine, I'd have gone 280ZX without a second thought.
The Mklotz kit actually fits a ton of 13" wheels, and probably all 14" wheels. 280ZX struts will fit almost all 14" wheels, but the 13s I have found that fit are the Diamond/Bassett racing steelies.
