67_1600 Posted September 28, 2014 Report Share Posted September 28, 2014 i dont kno what you mean by Splayed out? yea i know i should cut them but if i have to add more to make it lower i don't want to have to buy more U bolts. Never knew u can Fuse a Battery. since it is way holds the Volts. i would think wit or without the Fuse it would Be a Toaster. Your inner U-bot in the pic below should be on the other (right) side of the ridge/hump on the axle. The U-bolts should be parallel and yours aren't - there is more distance between the tops of the bolts than where they go through the plate below (splayed). The ridge is to keep your U-bolt in place. Quote Link to comment
DatsunSwag22 Posted September 28, 2014 Author Report Share Posted September 28, 2014 Oo I get u. For some reason on one said I wasn't able to get them closer. The shock was giving me problems. I'll work on fixing tht. The other is looks good right? Quote Link to comment
