VintageIron Posted September 21, 2014 Report Share Posted September 21, 2014 I finally got started on the body restoration. Cut out the rust and began repairing panels. This car was built by Toy Ermish 9-10 years ago for another Father / Son project that never happened. The car sat for 7 years before I acquired it. L16, Z 5-speed, wildwood disc brakes, Z drums on the rear. Mechanically good, the body was sound and just needed cleaning up. The plan: Windows out, Bright Red Paint with Ghost Flames on doors. . . . new body seals from Datsunland Socal 1 Quote Link to comment
housew Posted September 23, 2014 Report Share Posted September 23, 2014 is this the beginning of a story that's already happened? and is it for sale? It is this ( http://sacramento.craigslist.org/cto/4678980727.html ) car right? can you tell us more about what troy did to set it up? I'm curious. Quote Link to comment
VintageIron Posted September 23, 2014 Author Report Share Posted September 23, 2014 Yes, it is done. Glad to see someone is monitoring. As for the work Troy did, I only have the prior owner Shawn's word. Shawn bought as a Father/Son project from Troy. Troy put in a rebuilt L-16. Shawn did not want his son to have lots of power so it was rebuilt stock with the Weber DGV carb. Z-5-speed. Camber plates, sway bars front and rear, battery re-located to trunk, roll bar and harnesses. P205/15 tires Shawn lives in Carson, NV and trailered the car home. When I bought it he trailered it to me, which was a good thing because the alternator had failed. The car was virtually never used and just sat at Shawn's for most of 7 years. The temp would spike, so I changed out the thermostat and then the radiator before determining it was the missing bypass hose causing the problem LOL. Added a bypass hose and no more problems. Quote Link to comment
housew Posted September 23, 2014 Report Share Posted September 23, 2014 very cool, glad to see another one returned to service. Much better than sitting :) Quote Link to comment
LilLance Posted September 30, 2014 Report Share Posted September 30, 2014 Awesome! I am eager to see the progress on this one. Quote Link to comment
67_1600 Posted September 30, 2014 Report Share Posted September 30, 2014 Yes, it is done. Glad to see someone is monitoring. As for the work Troy did, I only have the prior owner Shawn's word. Shawn bought as a Father/Son project from Troy. Troy put in a rebuilt L-16. Shawn did not want his son to have lots of power so it was rebuilt stock with the Weber DGV carb. Z-5-speed. Camber plates, sway bars front and rear, battery re-located to trunk, roll bar and harnesses. P205/15 tires Shawn lives in Carson, NV and trailered the car home. When I bought it he trailered it to me, which was a good thing because the alternator had failed. The car was virtually never used and just sat at Shawn's for most of 7 years. The temp would spike, so I changed out the thermostat and then the radiator before determining it was the missing bypass hose causing the problem LOL. Added a bypass hose and no more problems. I'm confused - your first post says you're starting work but here you say it's already done and done by Troy? Seems like maybe you were going to try and take credit for work done by someone else and got caught but maybe I'm wrong... 2 Quote Link to comment
VintageIron Posted September 30, 2014 Author Report Share Posted September 30, 2014 I actually started the refurbishing build months ago and just decided to start a thread. I will get some more photos loaded of the progress. Troy set up the car before the prior owner purchased 9 years ago. I am not looking for credit for Troy's work :thumbup:. Quote Link to comment
VintageIron Posted October 1, 2014 Author Report Share Posted October 1, 2014 http://i120.photobucket.com/albums/o161/mjward510/IMG_0300.jpg Quote Link to comment
VintageIron Posted October 1, 2014 Author Report Share Posted October 1, 2014 Mocking up the flames. Quote Link to comment
VintageIron Posted October 1, 2014 Author Report Share Posted October 1, 2014 Mocking up the Flames Masking the flames Transfer the flame to the other door. Quote Link to comment
VintageIron Posted October 1, 2014 Author Report Share Posted October 1, 2014 Ghost flame painted and under mid-coat clear Flame when the sun hits it. Quote Link to comment
angliagt Posted October 1, 2014 Report Share Posted October 1, 2014 Isn't there a 510 forum? Quote Link to comment
VintageIron Posted October 2, 2014 Author Report Share Posted October 2, 2014 Probably, I am new to this forum stuff and thought I was in the right place for builds, if not move it, kill it , or let it die. Quote Link to comment
