Toney Posted September 21, 2014 Report Share Posted September 21, 2014 So as stated above the latch no longer latches. I messed with it for a couple hours yesterday and the same result every time. I close the door and can pull it open every time. Has anyone run into this before? Should i try finding another one? I pulled it off cleaned it up with some wd-40, spring seems to be ok. Most likely its something simple as usual. Thanks! Quote Link to comment
datzenmike Posted September 21, 2014 Report Share Posted September 21, 2014 Is the pull lever on the car inside stuck? Either the handle or the rod. The door thinks you are opening from the inside all the time. Quote Link to comment
Toney Posted September 21, 2014 Author Report Share Posted September 21, 2014 Awesome I studied it a little harder this time.The lever was just barely engaging so I adjusted the rod. Easy simple fix I was overlooking. Thanks for the help Quote Link to comment
datzenmike Posted September 21, 2014 Report Share Posted September 21, 2014 :thumbup: Quote Link to comment
