willz Posted September 16, 2014 Report Share Posted September 16, 2014 Found a 1985 nissan 720 4wd frame with running gear (no motor or trans) what would it take to throw my 620 body and engine over, or would it be easier to move all the 4wd stuff onto the 620 frame? I realize there would be some cutting and welding involved Quote Link to comment
datzenmike Posted September 17, 2014 Report Share Posted September 17, 2014 Four wheel stuff swapped into a 620 would be a monumental task, I know. The 620 body and box will fit a similar 720 frame. (more or less) but it has to be reg cab short wheel base 620 to a reg cab short wheel base 720. King Cab to King Cab although a long wheelbase frame is the same and will work if you move two of the bed mounts back about 8" and weld them back on. The 4x4 frame is slightly different than the 2wd frames but the only concern is the body mounts are higher. 620 steering column and box are integral so you will need to use the 720 steering column. I don't know if the 4x4 came without power steering. There is no way to power the pump on an L20B and steering a power steering box without assist might be tough. The 280zx is an L motor and they did have PS pumps. Maybe swap something like that over?? Don't know. HOWEVER the oil pan won't clear the front differential. You'll have to make something for that. The '80 4x4 720 had L20Bs but the diff was on the opposite side so that pan won't work. Otherwise your rad, L20B with mounts and engine brackets, transmission should fit.Note that some 720 used a short 5 speed and you 620 transmission is a long. Either shorten the too long 720 primary driveshaft or find a shorter one from a 720 with a long 5 speed. Quote Link to comment
willz Posted September 17, 2014 Author Report Share Posted September 17, 2014 So I'm better off doing a toyota solid axle front end... Quote Link to comment
willz Posted September 17, 2014 Author Report Share Posted September 17, 2014 What I really want to do is a complete independent front suspension on the truck but I'm not quite sure where to start Quote Link to comment
wayno Posted September 17, 2014 Report Share Posted September 17, 2014 Nissan/Datsun 4X4s did come without power steering, the 1980 4X4 is a good example. You can also put a Nissan Sentra power steering pump(I forget the year, 90s) on an L20b on the driverside real low on the block, as I have done it, but I had to fabricate a mount bracket. Quote Link to comment
willz Posted September 17, 2014 Author Report Share Posted September 17, 2014 What options do I have for an independent front suspension? I'm planning on doing more fast driving than boulder crawling Quote Link to comment
wayno Posted September 17, 2014 Report Share Posted September 17, 2014 The Datsun/Nissan 720 4X4 already has front independent suspension. Quote Link to comment
willz Posted September 17, 2014 Author Report Share Posted September 17, 2014 Does anyone make any aftermarket a arms? Or is there anything out there that sorta bolts on? Maybe someone has done something similar... From what I've found everyone is into the straight axle 4x4 but I'm looking for more of a dune killer/prerunner Quote Link to comment
datzenmike Posted September 17, 2014 Report Share Posted September 17, 2014 You'll have enough to keep you busy swapping the body to the 720 frame. First things first. See how you like the 720 IFS. Quote Link to comment
willz Posted September 17, 2014 Author Report Share Posted September 17, 2014 Well the 720 I was looking at is an extended cab, so it's out if the question now. What I'd like to do is get the 31's to fit first and figure it out from there Quote Link to comment
