rojadoja Posted September 9, 2014 Report Share Posted September 9, 2014 Here's what I know: The dizzy in my 76' 620 is marked T3T20389 221011W11 I want to swap to the Pertronix module but their part finder is designed for someone who knows more about their current situation I need to know: Can I upgrade my distributor? If so, any write-ups been done on this? Any advice as to which part number(s) to purchase? Should I just swap to a matchbox? Quote Link to comment
67_1600 Posted September 9, 2014 Report Share Posted September 9, 2014 Single or dual point? If it's single, it's generally a pretty straightforward upgrade unless your distributor has a part on the cam that prevents the Pertronix unit from sliding on. If you have a distributor like that, you'll need to grind that part off. I've read that you can install on a dual point distributor but it's not just a clean swap like it is with a single point. I've got Pertronix on my car and have had it on several others and have liked it with every install. The part number you want is 1741. 1 Quote Link to comment
Stoffregen Motorsports Posted September 9, 2014 Report Share Posted September 9, 2014 Be sure to read their instructions regarding ballast resistor and coil requirements. I used to run them with the stock 1.8 ohm ballast resistor and a MSD blaster coil. Never had a problem there, but other people were always burning them out. So read the instructions just to be sure. Quote Link to comment
banzai510(hainz) Posted September 9, 2014 Report Share Posted September 9, 2014 There is a ring above the point lobe on the L20b distrbutors. this must be ground down or machind down to the magnet ring in the Pertronix kit will fit on the point lobes. but forst see if the pertronix module lines up on the holes proved when the points are removed. Most wil fit but ai had one L20b dist that it would not fit. dont know why. 1741 is the kit you want. better take photo of inside distributor Quote Link to comment
Z-train Posted September 9, 2014 Report Share Posted September 9, 2014 A factory Electronic Distributor is SUPERIOR to Pertronix in every measurable way. 1 Quote Link to comment
rojadoja Posted September 10, 2014 Author Report Share Posted September 10, 2014 It looks like the electronic type that I had on my 79 are readily available at o'reilly. (Cardone 31-610). Think this will swap over? Quote Link to comment
banzai510(hainz) Posted September 10, 2014 Report Share Posted September 10, 2014 key is will the one from cardone fit your dist mount? as the were 2 types of matchboxes. if not then you have to move the oil spindal to get the timming right for that mount. also you have a point coil and a ballast resisitor in your 76. The newer dist will work but you goto to take the 12volt right at the ballast resisitor(use a double lug connection) then hook up to B of matchbox. C goes to the - side coil. using the ballast keeps the coil from getting hot or skip the ballast and buy a MSD coil or a 79 coil. why not go to a Datsun meet and meet some peole that might have this stuff and will do it for you. Lots of help in Bothell/Everett area why not look in the HOW TO section and its all there just look back and its all there Olddatsuns.com the tech section Quote Link to comment
scooter Posted September 12, 2014 Report Share Posted September 12, 2014 DO NOT TAKE THE TAPE OFF THE RING PART Those who have done this know why. Lol. I put one of these in my truck with good results, you gotta machine the collar off for them to work. I had to retime after but no big deal. Quote Link to comment
tr8er Posted September 12, 2014 Report Share Posted September 12, 2014 I got one with magnets all mixed up out of box. I had to remove tape and fix them. Sucked. I'm wondering if I got the one you fucked up, re-taped and returned... Quote Link to comment
banzai510(hainz) Posted September 12, 2014 Report Share Posted September 12, 2014 I put super glue or a enamel of the tape edge so it don't peel. also once in I just wipe them when they get dirty. don't pull the ring out as the magnets might slip under the tape and stay on the dzzy shaft. one can get spare rings Quote Link to comment
scooter Posted September 14, 2014 Report Share Posted September 14, 2014 Tr8er I still have it, I didn't return it 1 Quote Link to comment
