1977 Nissan Patrol Ute resto-mod
the japs made some cool 4x4s. First Patrol was a clone of the willys also.
http://offroadaction.ca/2010/08/24/4-door-mitsubishi-built-willys-jeep-wagons/
one was for sale maybe year ago here down the street from me. a 3 on the tree trans red with white as on the lower photo.
just dont want to deal with part issues.
where I grew up a guy had 3 Patrols.Back then i thought it was just Jap junk. find out the cj5 is kinda junk
however I do love my XJ Cherokee. all the comforts and parts avail cheap
find it was in Covington Wa
http://www.ewillys.com/tag/mitsubishi/
  • Replies 137
I zipped down to Moab on Friday and picked up an SD33T from a IH Scout. Got it for a good deal. It is complete from fan to transmission. I am going to scrap it for parts and use in the build too. Reason, I think the head is different as it is a factory turbo head and my others are N/A heads. The block may or may not be different. There is debate in Patrol circles about the N/A having oil jets for the pistons. At some point Nissan started putting the oil jets in all SD33 blocks but nobody can really say what year they made the change. My basic engine to start with is from an 83, I do not know if it has the oil jets until I crack it open. By having the factory turbo block I should be covered though if my N/A lacks them.
In a couple weeks I think i will get all this shit to the machine shop. And send off the turbo, IP and injectors to the IP shop.
On another note, the guy in Spain I got one of the IPs from, he can get new from Nissan crate SD33T engines. He sent me some videos of them. Price is $3,000 euros plus $700 euros in shipping. Pretty expensive but not awful I guess for a brand new crate engine. I myself don't need it but it is nice to know that crate SD33Ts are still out there in the world.
Cheers
Got me a Hotsy rented. main goal with it was two rolling chassis but those are done so I am proceeding to other things. Got it till Monday. Cleaned up the SD33T from the Scout I picked up recently in Moab. I put my money on this being original paint on the motor. it cleaned up nicely and the Hotsy sure takes care of business when dealing with decades of oil, grease, sand, gravel, dirt, mud, grass, funk!
10404075_720705278024971_823469993140383
1978780_720705508024948_3910917433561181
1937432_720705631358269_1376184352868820
1510824_720705741358258_4815868119538173
A couple of clean Nissan motors
10850035_720705824691583_148912053258946
A couple of pics from a 64 rolling chassis that got cleaned
10428639_720216388073860_398112169544930
10847924_720216194740546_494763463901981
Cheers
  • 1 month later...
Updates?
Been in Baja, returned recently. Rather still be there!
SD33T diesel is at the machine shop. I took it in awhile ago but am in no hurry. Talked to them today. Bad news, the Scout head pictured above is cracked badly. Hoping the head on the engine is ok, they pulling it on Monday. If not I got one spare in unknown condition. If that one is bad too, big bummer as I will need a new head. Will be hard to find and run me $1000+.
Not much else to tell about the Ute. Baja was great though!
10945465_10200225938969099_4301461615477
10353243_10200255070817377_6640276009822
10620248_10200225944969249_3823807152826
Cheers
That a Dana 27?
Sorry, missed this post.
No it is a Nissan C216. For years and years and years and to this day Nissan uses numbers to designate diffs. The number is ring gear in mm. C200, C216, H233 and H260 are all common Patrol diffs. But the old ones only had C216's and H260's. Front axle is a super old school design, known as the ball and claw or technically called a "tracta joint". Although they did go to a CV by the early 1970's. Pretty much every Patrol in the USA though has the tracta joint.
Cheers
Cheers
I see the difference, I was just going off of the closed knuckle.
Some of the pics I saw of them were in jungle terrain. Is there not jungle in Baja? I've never been so I don't know.
All desert man. Very dry place. Forests of cactus for miles and miles. Few oasis though with palms and a river. Maybe that is what you saw?
Cheers
Alrighty, talked to the injection shop. Probs with the pump are where it mounts to the engine is a bushing. This is all auged out and egg shaped, that makes the case toast. So it is not cracked but still toast. Barrel and plungers are also shot along with some springs. I got a spare TD pump I am gong to send them next week. Hoping that solves the issue with the case. New barrel and plungers are not all that expensive. They were quoting nearly $1000 for these parts in their price quote which was $2900. Still going to be hard on the wallet but better than $2900 before parts! Injectors not to bad but full rebuild on all six is only $250, that is great! No word on turbo yet but not much to a turbo so that shouldn't be to bad.
Have not found out if the head came back ok after pressure test but I am guessing it did.
Will have a lump of cash into the engine but it will be brand new, ready to go for hundreds of thousands of miles and I am not cutting any corners. Doing it up right!
I am thinking it will still be 2-3 months before it is all said and done and back here at my place. I am ok with that, just want it done right the first time and be ready to rock and roll.
So not only will this be the ONLY vintage Patrol pickup in the USA with a turbo diesel, it will have a brand new motor. :)
Cheers
