Source for speedo pinion gears?
Tech-guy
  • Replies 13
You obviously have a speedo reading way too fast from a transmission that was in a vehicle with larger diameter tires and a low numerical differential, like a 3.364.  Your car (if you had filled in your profile) has either smaller tires or a much higher numerical differential like a an old 520 with 4.889 differential.
More info.
What vehicle do you have. This might tell me the differential ratio.
What Datsun 5 speed?  Early 200sx or 71B?
It is a 280zx 5 speed with a 4.11 LSD and 195/60R14 tires.
Driving this car in 5th gear at an indicated speed of 70 mph, my GPS unit indicates 64 mph. So the indicated speed is 10% higher than the actual speed.
I removed the pinion gear and counted the teeth:  there were 21. In order to reduce the indicated speed by 10%, I need to increase the number of teeth by 10%; which in this case is 2 teeth. So a 23 tooth speedo gear will give me very close to the true speed.
Oh yes, I found a 23 tooth gear up in the NE.
The 23 tooth pinion gear works perfectly.  Indicated speed now matches GPS.
As for GPS accuracy: I checked GPS speed vs speedometer speed in both a 2013 FRS and 2008 Mazda 3, in both case they matched.
I do not know what this 23 tooth speedo pinion came out of; it was an optional gear available for several different 5 speed gearboxes.
  • 1 month later...
Where the heck can I get a 23 tooth cog?
I need one badly for my 510 with 81 280zx trans, 195/60r14 tires, 4.44 Subaru VLSD R160 diff
If anyone knows any dealership that stocks 22-23 tooth speedo cogs or has an extra one please PM me or post here!
Wayno there were no 4.44 diff 720s there were 4.375 and 4.625.... that's it. Plus the tire size would throw it out.
Assuming the stock 510 was 3.90 differential, 5:60x13" (24") diameter tires and a 17 tooth pinion gear... then 3K would read 55MPH
A 4.44 differential, with 195/60R14 (22.21") diameter tires, then 3K would read only 44.66 MPH. Roughly 23% wrong
23% added to a 17 tooth pinion is 20.91 teeth or 21 tooth.
You are in luck, the S12 (200sx) did use a 21 tooth on some models. There are two ways to go here. You can replace the plastic gear on the zx sleeve (for about $15) with the 21 tooth or replace the entire sleeve (about $30) with the 21 tooth gear in it. To be safe I would recommend buying the sleeve with the gear already on it.
21 tooth plastic gear........................... 32703-86401
Sleeve assy with 21 tooth gear........... 32702-E9821* I'm more confident doing this.
Thanks for chippin in mike, I had purchased a 21 tooth red cog and sleeve assembly from the Z store because they had it in stock, but after I installed it my speedo is still 5-10% too fast.
Each tooth is worth about 5% change, roughly.
Are you comparing to another car? I don't trust GPS measurements.
I am comparing vs a 2014 Ford Focus and also a GPS, the focus is about 1mph faster on its gauge than the GPS. my speedo reads about 5-6% faster at 40mph and 10% faster at 85mph.
I know there are not any 4.44 diffs Mike, all I asked is what color he was looking for, I have a couple of them around here.
