I shouldn't be allowed to own...
Jeeebus DaBlist. Skills man! And I hear you. When doing a painting, so much time is spent looking or planing. Hard to bill for that by the hour!
  • Replies 295
Tacked lip to valance
IMG_20160529_140933793%201_zpsvstd7bpa.j
Didn't like how the outer openings are so close to ends. Would make wrapping the ends around into the body look all wrong, So more slice and dice
IMG_20160529_142549911%202_zpsfquh5hrz.j
IMG_20160529_152057561_HDR%201_zpstgspyy
Liking this better
IMG_20160530_172200528_zpssswxsahy.jpg[/url]
I know it was taken outta context but think it still applies
  • 1 month later...
Well I thought I was on a roll with finishing this front valance when I really screwed up.
First - I took it off the car to finish welding where the ends were pieced together, so much nicer
working up on the bench.
Second - I saw someone welding sheet metal and after each little weld they blew it with an air nozzle to keep the heat down so I started giving each weld tack an up close blast of air, but didn't realize I had just learned a new way to shrink metal so all the curves tighten up. Had to slice the ends up to get it to fit.
May end up running a bumper to hide where the panels join
  • Like 3
  • 3 weeks later...
Ended up buying two AC/heat/defrost units (sure glad Tanker is paying for all this). Bought an Old Air Hurricane first for it's cube shape to mount above the passenger foot well so I could still have room to raise the trans tunnel later if needed for different engine trans combinations but it stuck out to far and hung down to low do to the upper firewall shape.
End up going with a Vintage Air Compac
  • Like 4
  • 3 months later...
Been working on getting the engine compartment ready for color and realized I should mock things up first and make the hard lines for the brakes and clutch.
Then I noticed the raised steering linkage was inline with the clutch master mount
But a little trimming and the clutch master fits fine
Jrock said to put some JB Weld on the end of clutch master and it should be fine cause he's seen it used on brake lines but decided to order a Tilton instead
The Tilton CM is still a little tight and may require recessing the mounting area.
Then I found this picture of a 370z CM and ordered one.
The 370z Cm is 11/16 bore vs 3/4 stock and the distance that it sticks through the back maybe problematic so will see which route I go
  • Like 3
370z Fits perfect on this side.
Ordered a banjo bolt and fitting to deal with the pressure fitting pointing at the frame
But required moving the attachment point on pedal arm farther away to keep the push rod angles good
IMG_20161113_133725421_zps6jmpyjms.jpg[/u
Nissan: Saving old BMW's since 2016
  • 4 weeks later...
Update: Life in the way
Daughter's Escape had the power steering go out. can't find pump, hmmmmmmmmmmm.
Didn't know a 2008 Escape had electronic power steering.  So replace $135 sensor cause internet, no fix.
Pay dealer $165 to tell me they would replace same sensor I already replaced and charge $600.
Bought complete electronic power steering unit (sensor, control module, electric motor) online $425.
All better
Drove it to work for three weeks without power steering while I let her use my car.
Then decided to take a chance on a Harbor Freight Generator so went Black Friday shopping first time ever.
But wasn't smart enough to buy the wheel kit and because there are no other projects in this tread to work on decided to build this
Back up to the generator for the front hooks
Fold down the rear hooks
and fits either direction
Hoping will be easy to move around outside and will be able to load in the pickup by myself using motorcycle ramp
  • Like 7
  • 4 weeks later...
