I shouldn't be allowed to own...
  • Replies 295
ET05 front and rear, here is where raising the front crossmember is starting to pay off. With the front tire tucked like this there is 4.5 inches of clearance under the crossmember. Once the tire flattens out under load I'm guessing still 4". Yes that fender is junk, another nice set came with the car
I got schooled for calling this a crossmember so I picked up another rear "subframe" and cut off the ends to use for repositioning the rear trailing arms. Shouldn't flex and twist which I think would have been a problem if I tried to work with what I had tacked together. When cut off wheels and band saws wont do a sawzall is your best friend.
Then IMO it's a crossmember,  not a subframe. I think you were right the first time.    B)
But you know how pedantic BMW guys are...   :rofl:
I'm just glad it's not British or I'd have to be using words like Boot and Bonnet
  • 3 weeks later...
that looks sick!!!
how do you reweld the wheels to be true?
