DaBlist Posted October 14, 2018 Author Report Share Posted October 14, 2018 I feel like getting Photobucket to let me post a picture was more of an accomplishment than installing a carburetor 2 1 Quote Link to comment
datsunfreak Posted October 15, 2018 Report Share Posted October 15, 2018 I like what you've done with the valve cover. I need to do that on the Z22 cover for my Volvo... Yes, I stole your bit and I'm building a European sedan with a Japanese engine... ? Quote Link to comment
DaBlist Posted October 16, 2018 Author Report Share Posted October 16, 2018 On 10/14/2018 at 5:53 PM, datsunfreak said: I like what you've done with the valve cover. I need to do that on the Z22 cover for my Volvo... Funny, lt only looks like that because I had to strip the wrinkle pant off to redo it Quote Link to comment
datsunfreak Posted October 17, 2018 Report Share Posted October 17, 2018 (edited) On 10/15/2018 at 8:35 PM, DaBlist said: Funny, lt only looks like that because I had to strip the wrinkle pant off to redo it I thought perhaps you had shaved/smoothed it a bit? And if you fancy following along with mine, which will likely not be as nice... ? Edited October 17, 2018 by datsunfreak Quote Link to comment
DaBlist Posted November 29, 2020 Author Report Share Posted November 29, 2020 (edited) Played with front struts a while back. This is just mockup at this point. Edited November 29, 2020 by DaBlist 3 Quote Link to comment
datsunfreak Posted November 30, 2020 Report Share Posted November 30, 2020 Are you keeping the funky add-on side markers? Quote Link to comment
DaBlist Posted December 1, 2020 Author Report Share Posted December 1, 2020 No, you can have them for the Galaxie 2 Quote Link to comment
datsunfreak Posted December 1, 2020 Report Share Posted December 1, 2020 12 hours ago, DaBlist said: No Good. I hate it when people leave those on... 😃 Quote Link to comment
DaBlist Posted December 23, 2020 Author Report Share Posted December 23, 2020 (edited) When I first installed the Weber I used a 1.75" tall adapter with plans to have a bulge in the hood to clear the air cleaner. Then recently decided to modify the stud location and port openings on the intake to bolt the carb on without any adapter Edited December 23, 2020 by DaBlist 2 Quote Link to comment
DaBlist Posted December 23, 2020 Author Report Share Posted December 23, 2020 (edited) Then time to rethink how my throttle cable was routed at the pedal. Anybody else hoard brackets? I can't throw out anything without first harvesting all the hardware and brackets off it. Flat screen mounts to the rescue, Cut, weld, grind. [U RL=https://app.photobucket.com/u/DaBlist/a/a679e6c8-237c-490f-9c7c-5d34037e4669/p/56593394-408f-4261-b42b-80dcc7688867][/URL] Edited December 23, 2020 by DaBlist 2 Quote Link to comment
DaBlist Posted December 23, 2020 Author Report Share Posted December 23, 2020 Time for tension rods as the factory ones are no longer the right length or angles. Used a donor set of tension rods and the adjusters from Mazda RX7 rear suspension links. 3 Quote Link to comment
datsunfreak Posted December 23, 2020 Report Share Posted December 23, 2020 Looking good! 👍 That gas pedal set-up is very crafty. Well done! Quote Link to comment
Lockleaf Posted December 25, 2020 Report Share Posted December 25, 2020 I too hoard brackets and hardware. That all came out really nice. Quote Link to comment
DaBlist Posted January 1, 2021 Author Report Share Posted January 1, 2021 (edited) Still need to weld on brake hose tabs. Nothing at the top is adjustable, just used spare collars for the top spring perch. I have know ideal what springs I will end up running, these are some 12" 200 lbs to get me started putting things together. Edited February 8, 2021 by DaBlist 2 Quote Link to comment
datsunfreak Posted January 2, 2021 Report Share Posted January 2, 2021 (edited) On 12/31/2020 at 10:53 PM, DaBlist said: I no ideal what springs I will end up running, these are some 12" 200 lbs to get me started putting things together. With a roughly 2000-2200 pound car, that's a great place to start. 👍 Edited January 2, 2021 by datsunfreak 1 Quote Link to comment
]2eDeYe Posted January 3, 2021 Report Share Posted January 3, 2021 Bracket hoarder here. lol Quote Link to comment
DaBlist Posted January 8, 2021 Author Report Share Posted January 8, 2021 (edited) Wheel Straight =Good Wheel Turned = Bad Kick Panel cut, section, massage, weld, grind, seam seal = Wheel Turned Good Edited January 8, 2021 by DaBlist 4 Quote Link to comment
datsunfreak Posted January 9, 2021 Report Share Posted January 9, 2021 No consideration given to a smaller diameter tire? 😁 Quote Link to comment
DaBlist Posted January 9, 2021 Author Report Share Posted January 9, 2021 49 minutes ago, datsunfreak said: No consideration given to a smaller diameter tire? 😁 Current thought is to start out running 195/60/14. Wanted to make room now so I would have room for options in the future. Without springs I may be cycling the suspension at limits I will never reach without air bags which is a thought I'm open to down the road. Also I have no idea what my caster is at the moment. I'm working with LCA in it's relaxed position. 3 Quote Link to comment
DaBlist Posted February 6, 2021 Author Report Share Posted February 6, 2021 It bothered me that the lower valance I added covers the factor tow points so a U-bolt, metal scraps, cut, weld, grind. 4 Quote Link to comment
]2eDeYe Posted February 7, 2021 Report Share Posted February 7, 2021 Nice detail 1 Quote Link to comment
