Jeremiah720 Posted September 3, 2014 Author Report Share Posted September 3, 2014 Well looks like I ran into a detour on my build. Last night pulling out of work my brake pedal went to the floor. Got home using my pbrake and looked for some leaks didn't find anything. Popped the hood and my master looks to be leaking into my booster. So I might as well do the 240 booster swap. Anyone know if I need the master and all from the 240? I need to make room for my turbo anyways so might as well get it out the way. Quote Link to comment
Jeremiah720 Posted September 6, 2014 Author Report Share Posted September 6, 2014 Well after much digging around in my garage I was able to find my Viper keyless entry kit I had laying around. Didnt get much done but figured I'd post anyways will finish up tomorrow and update this post.I also had tons of wire I pulled out of cop cars in the salvage yard. Good place for wire these idiots dont yank it out lol. So I got the passenger side pretty much done just need to finish up a lil.Now the biggest problem I had was the door jam. I didnt wanna have wires hanging or getting pinched so I went digging around the salvage yard and found 2 rubber booties off the back of a subaru tailgate. One side fit perfectly in the already existing hole in the cab however there wasnt a hole in the other side of the door....so I drilled one 1/2 inch hole as its the size of the inner diameter of the rubber boot. I pulled it through nice and snug.After I got it through I put a washer in there like so to make sure it wouldnt come out. Which I doubt it would of but it was just in case. I couldnt get a good pic of it in the door jam. So I took a quick pic for an example while cleaning up.So heres the actuator mounted up. Was a pain in the ass as I didnt have a lot of room to mount it because the window would hit it coming down. And couldnt mount it like I would any other car (on the outside) because the door card wouldnt go back on. Finally After fiddling around I got it in the right spot where it barely misses the window and works just fine. Ok well Ill finish up tomorrow. Still have the alarm headlights door sensors and other side to put in. Quote Link to comment
Nissan_Boy85 Posted September 6, 2014 Report Share Posted September 6, 2014 Do you have any more info on the 240 master swap? I'm intrigued... Quote Link to comment
Jeremiah720 Posted September 6, 2014 Author Report Share Posted September 6, 2014 Yeah it was a 300zx booster basically the same bolt pattern same size booster without the long ass pole.tho i am interested in the 240 booster as it is slimmer however idk if it supplies enough assistance for its purpose .but what I don't know is if the arm reaches to the brake pedal arm on the 300zx and the master cylinder. Looks like it would just bolt in fine. Still waiting for someone to chime in on it. I will probably go ahead with the 300zx and let you know if I had to mod anything to fit. 1 Quote Link to comment
_chiefjt Posted September 6, 2014 Report Share Posted September 6, 2014 I think the 300zx booster would hit that top lip on the firewall and also the clutch master cylinder. Have you lined up both boosters with the mounting points side by side. Cause if the shafts line up it should work. Quote Link to comment
Jeremiah720 Posted September 6, 2014 Author Report Share Posted September 6, 2014 I'm not worried about the lip. I have thick aluminum spacers I could use. If I did use the 300 I'd have to move the clutch master over. I'm still exploring my options on boosters. Quote Link to comment
wayno Posted September 6, 2014 Report Share Posted September 6, 2014 Why do you need to use a booster from something else? Is it to big, and it gets in the way of something? Quote Link to comment
Jeremiah720 Posted September 6, 2014 Author Report Share Posted September 6, 2014 Yeah the turbo will hit it when I put it in. Kinda test fitted things up. I'd also like more room visually Quote Link to comment
wayno Posted September 6, 2014 Report Share Posted September 6, 2014 Look into using the 1980 Datsun 720 booster, it is slightly smaller, but more importantly is it is closer to the firewall, and it bolts in. Now I am not saying that all 1980 720 boosters are the same, you need to find the smaller one that has the short pedastal, I guess it depended on who showed up for work that day, seems like no two Datsuns were built the same. Quote Link to comment
Jeremiah720 Posted September 6, 2014 Author Report Share Posted September 6, 2014 Will look into that thanks wayno . I think it was just the crossing road in the 80s where technology was really changing. Quote Link to comment
Charlie69 Posted September 8, 2014 Report Share Posted September 8, 2014 Wayno is correct. I have seen 1980 720 built with the little 620 boosters, My 86 720 King cab booster is larger than my 1980 720 that looks like Waynos diesel booster. Quote Link to comment
_chiefjt Posted September 8, 2014 Report Share Posted September 8, 2014 I would use the 1980 booster. Keep in mind since it's shorter the brake lines need to be shorter as well. Maybe use the '80 brake lines?? Quote Link to comment
wayno Posted September 9, 2014 Report Share Posted September 9, 2014 You would have to look at the brake lines to make sure they are arranged the same way, it seems that Nissan put a load sensor on the frame under the passenger seat, on some of the 720s, the right front brake line is tied into this sensor while others it is not. I find it easier just to bend the existing brake lines to fit, but that is just me, and if it breaks, then I just make a new line, or re-flair the old one. Quote Link to comment
that-son Posted September 10, 2014 Report Share Posted September 10, 2014 you can't just post a picture when you install the turbo. we gotta see it in action! at least dolby surround 5.1... Quote Link to comment
Jeremiah720 Posted September 10, 2014 Author Report Share Posted September 10, 2014 It will be a while before I install the turbo. As I said this will be a long process I make good money but I'm not rich haha. First I need to get fuel injected. Then I need to tune it. I'm buying a 2nd z24 to build up as my 720 is my daily. Which I'll just be getting forged pistons. And full rebuild of the head with stiffer valve springs. It will be a while but I'll still keep trying to do smaller projects as I go. I'll post my keyless entry when I have time. I'm all done with it. Quote Link to comment
