Jeremiah720 Posted September 2, 2014 Report Share Posted September 2, 2014 Well my end result of my build will be a fully restored 720 with a Built Z24ET and custom body modifications custom interior. So sorry to stock die hard lovers but this will not be a 100% original restore on a Very nice truck. I kinda feel bad myself doing such. But I vow to keep it as original as I can. I will use what the 720 has and add a little spice. Heres some of my small mods to my 720 so far. Not much but will be fun a long the way. This will be a long process but plan on doing a few things per month and updating everyone along the way. My 720 Seats from a 2006 Scion TC Center console is from a 90's Dodge Neon 6inch kick panel speakers. 6x9 Speakers in the rear below window. Had to cut a little metal inside the body with a jigsaw but hey it fit very nicely. Sound is great its nicely spread through the whole truck rather then just coming from the front or rear. Welded up some new exhaust out of old 2.25 pipe I had laying around. Also had a flowmaster sounds awesome. Not too loud but with a growl. 1 Quote Link to comment
_chiefjt Posted September 2, 2014 Report Share Posted September 2, 2014 Nice. Haven't seen an z24et. Custom intake with Megasquirt? Quote Link to comment
newdatsunowner720 Posted September 2, 2014 Report Share Posted September 2, 2014 How hard is it to change the suspension in my 84 720? Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 Nice. Haven't seen an z24et. Custom intake with Megasquirt? Z22E Intake manifold bolts up to the z24 and the injectors will support a 2.4L only problem is z24 ports are square and the z22 are round, also youll have to port the head a little bit for the injectors spray pattern and yes I will be using megasquirt for this build. How hard is it to change the suspension in my 84 720? Depends what is it your wanting to change? Quote Link to comment
720inOlyWa Posted September 2, 2014 Report Share Posted September 2, 2014 Do those seats give you adequate thigh clearance? Great idea with the console. I had been looking for a stock one in tan, but seeing yours, I may broaden my horizons a bit. You and I have the same exact truck- except mine is normally aspirated / 5 speed. Except for things that make it drive better / be more comfortable, I am going to leave mine as stock as possible. It really is a pretty great driving truck now that it is all fixed up. I may just find a set of used 720 buckets to recover / rebuild. Mine are okay, but a nice set makes a huge difference, as you know. Nice truck! (I love mine.) Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 The seats add about 1 inch higher better feel on the pedals and more adjustability. Bit more led room and easy access to the rear of the truck using the handle on the side of backrest. I'm still pretty much bone stock. I still have my old seats one with no tears and the drivers is a bit more worn with the tear in the butt of the seat. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 I have a set of Neon seats in my 720, they sit an inch higher also, I personally don't like it, I have a kingcab so I don't need to be higher, as I can move back. I guess it's a personal preference, once sitting in the lower position on the many 720s I have owned, I got used to the stock feeling. Another thing I noticed is what was mentioned, when I sit in my 720 with the wheel tilted down, it's less than an inch from my legs, and it makes it difficult to enter/exit the truck, but I finally just got used to the wheel being tilted up or in the middle. Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 I don't have the tilt steering wheel so its not so close to the seats. I'm tall so being so low in a seat is very uncomfortable. Also the tc seats adjust on the back support and thigh so I am really liking the seats. Plus heated for the winter....as soon as I wire it in anyways. Once again thanks for the intake manifold wayno. I hope to get started sometime this week or at least get all my parts in. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 Your Welcome, I hope it works good for you. Having the non-tilt wheel keeps issues from being created, but I am spoiled, I like my power steering, so everything I have(520/521/720) has power steering, I cannot recall if I have ever seen a non-tilt power steering column before. Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 Haha sadly I don't have power steering. I been thinking about adding rack and pinion but haven't got to planning it. And I also wanna use an electric pump design. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 The 720 has a stock power steering package, why re-invent the wheel on this? Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 I like rack and pinion over the gear box. That and I have a friend who's a manager of a salvage yard. I do wha I want lol. Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 But ahh. Where do I get this package lol. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 Just look for a 720 with power steering, but you need it all, the steering gear, the column, the pump and adjustment pulley, the piping and the lower balancer if you don't have the right one on your truck now. Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 I have the right harmonic balancer I think as it has 3 different pulleys and I'm only using 1 for water and alt. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 Yep, that's the one you need. All my power steering setups except for one are custom setups, meaning that I have to fab up brackets for the pump on the L20b or diesel engine I have in my trucks. I have one diesel power steering unit, I wish they were all that compact, it's down real low on the engine, out of the way. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 I got to thinking about it, you might have to use a hardbody pump with the remote reservoir, as all the Z block units have the pump/reservoir right where the front of the electronic fuel injection assembly/manifold is. Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 I'll figure that out after I build the z24et as I want the least amount of stuff in the way. I'll most likely be doing a custom setup with a rack and pinion. It'll be a fun experience. Like I said still planning that stuff not sure where I'll go with it. But thanks for the info, its a start. Quote Link to comment
wayno Posted September 2, 2014 Report Share Posted September 2, 2014 I need to make a correction, I said all the Z block units, when I should have said all the 720 units, the hardbody pump is small and is low/mid on the side of the engine, that pump was used on a lot of Nissans, the reservoir is separate/remote and can be put out of the way. You can see my reservoir is in the back corner of my engine compartment(diesel), the pump is on the front of the engine high, but can be put low if you have the room. Quote Link to comment
that-son Posted September 2, 2014 Report Share Posted September 2, 2014 did the scion seats bolt right up? also did you bother with sound treatment? i find my 720 a little noisy inside the cab and am contemplating between peel n stick or gtmat. and maybe a heavy dose of bed liner on the outside. Quote Link to comment
newdatsunowner720 Posted September 2, 2014 Report Share Posted September 2, 2014 Well Z22E Intake manifold bolts up to the z24 and the injectors will support a 2.4L only problem is z24 ports are square and the z22 are round, also youll have to port the head a little bit for the injectors spray pattern and yes I will be using megasquirt for this build. Depends what is it your wanting to change? Well I'm looking to make my ride a little less rough, I'm New working on vehicles so i dont know what would be the easiest fix for that Quote Link to comment
newdatsunowner720 Posted September 2, 2014 Report Share Posted September 2, 2014 Sorry I quoted the wrong person Quote Link to comment
_chiefjt Posted September 2, 2014 Report Share Posted September 2, 2014 Yeah, I knew the z22 intake would fit. I was just saying I've never seen an z24et done before. Idk why but I have a feeling this thread might die. I could be wrong though. As many have brung up building a z24 including myself and very few that I've seen actually did it. Sorry to be all negative but I hope it boosts your confidence to keep going. lol 1 Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 Lol it won't die I'm already buying everything. My megasquirt will be here soon. And already have the manifold from wayno. I already have my turbo too. Just piping left and what not. 1 Quote Link to comment
Jeremiah720 Posted September 2, 2014 Author Report Share Posted September 2, 2014 Well Well I'm looking to make my ride a little less rough, I'm New working on vehicles so i dont know what would be the easiest fix for that Well the best thing you could do is replace all the bushings with rubber not energy. Check your ball joints and tie rods to be sure you don't have any play. Use energy bushing on your sway bar and links only. Get better performance shocks. did the scion seats bolt right up? also did you bother with sound treatment? i find my 720 a little noisy inside the cab and am contemplating between peel n stick or gtmat. and maybe a heavy dose of bed liner on the outside.No I didn't bother with any treatments as the interior will be gutted. Custom fiberglass panels for a sub and the 6x9s in the rear. Dynomat in the interior bottom front read and doors. I just needed some tunes for now. My trucks in such good shape the only noise is my loud ass tires on the highway. Who ever had it before me took care of it. He was selling it to a salvage yard and I saved it. As for the seats, no it wasn't a bolt up kind of deal. I ended up drilling new hole and using big washers and lock washers. When I have the cab off I'll fill in the old holes and weld the new nuts on. Quote Link to comment
