DATSUN671 Posted August 31, 2014 Report Share Posted August 31, 2014 So I have a fully rebuilt l20b. It has a mild web cam, dual mikuni 44 side draft setup. I also wanted to know where should the timing be set at. It has a weak top end power. When it takes off it bogs out then it will pick up speed.could it be my carb tuning or my timing. Thanks for the help. Quote Link to comment
banzai510(hainz) Posted September 2, 2014 Report Share Posted September 2, 2014 try about 12-15deg BTDC your carbs good? I seen a guy had the accel pumps installed wrong(upside down) on his supposedly rebuild carbs he got on the internet Quote Link to comment
