MacGuyver-isms or quick fixes temp. or not also halfa$$ed repairs
that-son
title is self explanatory.  post your less than ideal repairs here.
the whole top of the shifter boot tore off plus two tears in the folds somewhere.  i first soaked the boot in greased lightning, dried it up, scuffed with sand paper then cleaned with brakekleen.  i then put a generous spread of rtv and let cure for 2 days.  if you look closely you will see some squeeze out.   in hindsight, i think i should have done several thin layers.  but seems to be holding up and i already had the rtv.
seat belts don't lock up so...
  • Replies 2
