that-son Posted August 31, 2014 Report Share Posted August 31, 2014 well it was a long and winding road (literally and figuratively speaking) but i finally passed it today. yeehaw! the numbers are above average but still below the maximum allowable. i'm happy. now i have two years to enjoy the truck and figure out how to get better numbers next time. a new carb and maybe a new cat. any ideas? for this test, ihooked up all vac lines and sprayed maybe two cans of carb cleaner down the carb and into the power booster vac line. maybe next time i'll soak the cat in a tub of degreaser or brakekleen. i've been ready to get it smogged for a few days now but things just would not stop breaking. this was the latest when i got to the smog station today. i've been hearing funny noises for a while now but that pulley showed no indication at all it was dying. i guess now i know what a dying pulley sounds like. could that have been from over tightening? i almost went home but upon closer inspection determined that it was just for the powersteering pump so i decided to cut the belt. i have three new belts anyway that i was planning on installing when i get a new radiator. i guess they're going in now. the question is... how do i fix it? i don't think it's covered in the haynes manual. looks like i lost a bearing. does that thing (can i call it a spindle?) where the pulley goes unscrew? how do i take it out? Quote Link to comment
wayno Posted August 31, 2014 Report Share Posted August 31, 2014 I would just go to a wrecking yard and buy a used one off another 720. 1 Quote Link to comment
that-son Posted August 31, 2014 Author Report Share Posted August 31, 2014 i still need to take it out though. and what is it called? i know it's a tensioner for the ps belt but what is its official name? Quote Link to comment
Ranman72 Posted August 31, 2014 Report Share Posted August 31, 2014 tension-er pulley for the power steering belt 1 Quote Link to comment
datsunrides Posted August 31, 2014 Report Share Posted August 31, 2014 Should be held to the front of the motor with a couple of bolts. You will probably need to cut the old bearing race off the adjuster. You can go to NAPA and get a new bearing for the idler. Remove the circlip, pound the old bearing out and install the new one. You will probably spend more for a used one at a yard then a new bearing and who knows how long the used one will last? 1 Quote Link to comment
datzenmike Posted August 31, 2014 Report Share Posted August 31, 2014 The long adjuster bolt will simply unscrew from the bearing part. The nut on the front locks it in place. Always remember to loosen first, then adjust belt, then tighten the nut. You don't need to remove the bracket that holds it to the engine. I believe the pully/bearing assembly comes with a new adjusting screw It appears that any Z series engine with PS has the same idler pulley/bearing including the '80-'82 S110 200sx. About $40 at the dealer. 1 Quote Link to comment
that-son Posted September 2, 2014 Author Report Share Posted September 2, 2014 well i got the thing where the pulley goes into fianlly all taken apart. i used a pipe wrench. it's pressed not threaded but the pipe wrench worked. i'll need some kind of puller or pounding jig to take apart the new one if it comes pre-assembled. any tips? Quote Link to comment
that-son Posted September 10, 2014 Author Report Share Posted September 10, 2014 got the new pulley and unlike the old one, it's only held in place by a lock nut. nothing pressed, no special tool needed. old part no. is 11945-w0500. replaced by 11945-03g0a. Quote Link to comment
