Hrvat9 Posted February 7, 2017 Author Report Share Posted February 7, 2017 22301-P7901. I'm looking at one sitting on my desk. "vacuum control assembly" Dude sweet! Thanks a lot :) next paycheque I'm getting that sucker and tuning the carb. Can you send the link too? Quote Link to comment
distributorguy Posted February 9, 2017 Report Share Posted February 9, 2017 Link??? Call your local Nissan dealer. Quote Link to comment
Hrvat9 Posted February 10, 2017 Author Report Share Posted February 10, 2017 Link??? Call your local Nissan dealer. Thought you were looking at it online Quote Link to comment
Hrvat9 Posted February 10, 2017 Author Report Share Posted February 10, 2017 Today I got my wheel cylinder for the right rear from rock auto. I frigged up my other one when I was bleeding the brakes. For the first time I have some what of a pedal! About 50/50 nothing to hard pedal. Haven't tested it driving but feels decent. Also what's the procedure in bleeding the prop valve with the brakes? Rear of prop then start at rear right brake like normal fashion and continue to the front of prop valve/ front brakes? Quote Link to comment
red13 Posted February 10, 2017 Report Share Posted February 10, 2017 Let u know skillard is working on troop kick plates, aka door sills Quote Link to comment
Hrvat9 Posted February 12, 2017 Author Report Share Posted February 12, 2017 Is there a way To get the front brake adjusters unstuck? They don't move at all. The toothed wheel part that is. I have them out now Quote Link to comment
sebpv Posted February 12, 2017 Report Share Posted February 12, 2017 penetrating oil? Or even just drop the fucker on the concrete floor Might make it budge Quote Link to comment
Hrvat9 Posted February 12, 2017 Author Report Share Posted February 12, 2017 penetrating oil? Or even just drop the fucker on the concrete floor Might make it budge Spraying pb blaster all over , gonna torch them tomorrow and see if they break loose...if not , to the concrete they go ! Quote Link to comment
Hrvat9 Posted February 21, 2017 Author Report Share Posted February 21, 2017 Bought new adjusters for the front, should be here in a couple of days. the old ones did not want to let go with heat or acid. I noticed when I take my battery out and hook it back up my charge light suddenly works for a bit. Tired battery ? Quote Link to comment
Hrvat9 Posted February 22, 2017 Author Report Share Posted February 22, 2017 Put The front adjusters on and WOW. what a difference! I have a semi firm pedal now when the car is off. It has braking hope! I bet it would be even better with new wheel cylinders all around since I only changed the right rear. That's next on the list Quote Link to comment
sebpv Posted February 22, 2017 Report Share Posted February 22, 2017 if the pedal is mushy it could be that the master cylinder needs replaced. If when off the pedal is mushy then the booster leaks Quote Link to comment
Hrvat9 Posted February 28, 2017 Author Report Share Posted February 28, 2017 HOGIE comes in clutch with the 620 parts again! After I donated my pass fender to the old batsun build , he sent me another Quote Link to comment
