mcordero8 Posted March 11, 2016 Report Share Posted March 11, 2016 RX620? I like it! Keep the pics coming. And potential plans In the near future ...need new housings though 1 Quote Link to comment
Hrvat9 Posted April 2, 2016 Author Report Share Posted April 2, 2016 Slowly but surely ....I will be driving it finally. Also got some rsx seats and r32 seats which I can't decide between 1 Quote Link to comment
Hrvat9 Posted April 7, 2016 Author Report Share Posted April 7, 2016 New parts for manual swap in! Thanks to HOGIE :) Also I found a 1988 d21 in a field with a 5 speed, are those usable ??? 1 Quote Link to comment
Lockleaf Posted April 7, 2016 Report Share Posted April 7, 2016 Yes that transmission is useable. If you are running an L series engine, you will need to put an L series bellhousing on the D21 transmission. If running Z or KA then that trans is fine. Likely have to have your driveshaft modified. 1 Quote Link to comment
Hrvat9 Posted April 7, 2016 Author Report Share Posted April 7, 2016 Yes that transmission is useable. If you are running an L series engine, you will need to put an L series bellhousing on the D21 transmission. If running Z or KA then that trans is fine. Likely have to have your driveshaft modified. Ah so I need an l series bell housing ... Which I might as well keep waiting for a tranny to pop up instead of taking this one out because it wouldn't bolt up 1 Quote Link to comment
Hrvat9 Posted January 19, 2017 Author Report Share Posted January 19, 2017 I always end up helping people with their projects and neglecting mine -_-, but now it's I n its new home, got a heated shop so shit actually is getting done. Sitting beside "batsun" I got a Mitsubishi 4g63t alternator (90amp) which fit perfect so I used it. Just had to mod the uppper bracket a bit. So much easier to start the truck now :) this being a 77 it was externally regulated but someone put a hitachi internally regulated on it. Without knowledge I assumed that's how it was suppose to be so I thought alternator was shot. Turned out it was the battery. I kept the stock alt in case I ever need it later. Now it's charging at 15.5. With lights and blower on it goes to 14.9. Still too high ? I haven't done the wiring mod to the external reg yet, the charge light is on and when disconnected it goes out. Would that make a difference or is the regulator in my replacement alt going ? Couple of questions, what's the white wire here for?? 2 Quote Link to comment
Hrvat9 Posted January 20, 2017 Author Report Share Posted January 20, 2017 Figured out that the blue wire did nothing for the electric choke, and the white wire had 12v. Hooked it up to choke and now it works. White was for the bcdd solenoid which I don't have Quote Link to comment
125 CSL Posted January 20, 2017 Report Share Posted January 20, 2017 like your shop, better lighting then mine. Quote Link to comment
Hrvat9 Posted January 31, 2017 Author Report Share Posted January 31, 2017 I had some ghetto fan switch hooked up / spliced in to bypass the oem switch. I took the "new" switch out and rewired the old one back up and only had the high setting blowing. Took out the connector at the heater and saw the coil was disconnected. Put it back on its posts and got the low setting back :) So I did the wire mod with the new alt ; white/blk to white/red, and white to yellow. Does this keep the idiot light intact too? When I turn the key on my idiot light doesn't work now but did when plugged into the VR before the mod Do I keep the VR plugged in now or do I ground the remainding black wire ? Is the white/blue wire for the charge light ? Quote Link to comment
Hrvat9 Posted January 31, 2017 Author Report Share Posted January 31, 2017 Also after the alt wire mod, this relay is now getting warm. What's this for? Quote Link to comment
Hrvat9 Posted February 1, 2017 Author Report Share Posted February 1, 2017 horn relay? No that relay is right beside this one that's getting hot-_- Quote Link to comment
Sanduners Posted February 1, 2017 Report Share Posted February 1, 2017 I had a 79 King Kab back in the early 80's. I loved that truck! I just picked up a 3rd member from a homemade trailer. Planning to sell these parts, has good axles and a 3.70 r/p. Quote Link to comment
red13 Posted February 1, 2017 Report Share Posted February 1, 2017 That's heater choke,relay, if u did a,internal,reg alternator that will remain on Mike knows best way to bypass. Also it will kill your battery Quote Link to comment
Hrvat9 Posted February 1, 2017 Author Report Share Posted February 1, 2017 AH that makes sense ! On the wiring diagram it doesn't say "auto choke relay" anywhere so I didn't know what to disconnect. Thanks! Would you happen to know why the charge light isn't working anymore after unplugging the external vr? Quote Link to comment
red13 Posted February 1, 2017 Report Share Posted February 1, 2017 could be auto choke relay wiring diagram says weird stuff. Mike is the one to know more about the set up Quote Link to comment
datzenmike Posted February 1, 2017 Report Share Posted February 1, 2017 I had a 79 King Kab back in the early 80's. I loved that truck! I just picked up a 3rd member from a homemade trailer. Planning to sell these parts, has good axles and a 3.70 r/p. Sorry, buying and selling are only allowed in the classifieds... http://community.ratsun.net/classifieds/category/5-drivetrain/?sort_key=date_added&sort_order=desc ... A 3.70 would be from a 720 or newer truck. Quote Link to comment
Hrvat9 Posted February 2, 2017 Author Report Share Posted February 2, 2017 Hey mike , I started another thread about my idle but I'll continue it here. I took the cap off the distributor and wiggled the Vac advance and it's solid as frig. So I unscrewed it and pulled it out. I doesn't even move , it's stuck open completely! No wonder I couldn't change the idle. Is there a way to get the diaphragm inside unstuck?? Quote Link to comment
sebpv Posted February 2, 2017 Report Share Posted February 2, 2017 compressed air on either end? Quote Link to comment
Hrvat9 Posted February 3, 2017 Author Report Share Posted February 3, 2017 compressed air on either end? Tried everything but no go. Just going to get a new one Quote Link to comment
Hrvat9 Posted February 3, 2017 Author Report Share Posted February 3, 2017 Still don't get why I don't have the charge light on ..it's just like this old post http://community.ratsun.net/topic/7830-saturn-alternator-how-to-wire-in/page-3 I have everything wired properly but no light with key on. When I ground the L on the unplugged alt plug it turns on :/. The white /black wire reads 4.60v and the white /red reads 9.60v. Those are the wires off the external VR that have to be joined. Should they have the same voltage? Quote Link to comment
Hrvat9 Posted February 7, 2017 Author Report Share Posted February 7, 2017 Cut out the battery tray since it was almost non existent. Welded in new sheet metal , prepped and PoR 15'd Quote Link to comment
distributorguy Posted February 7, 2017 Report Share Posted February 7, 2017 The diaphragm is not stuck - its petrified! You can still buy that vac unit from the dealer for about $30. Get a new one. Quote Link to comment
Hrvat9 Posted February 7, 2017 Author Report Share Posted February 7, 2017 The diaphragm is not stuck - its petrified! You can still buy that vac unit from the dealer for about $30. Get a new one. Aha I know right! And seriously?? Nissan carries that still? Quote Link to comment
distributorguy Posted February 7, 2017 Report Share Posted February 7, 2017 22301-P7901. I'm looking at one sitting on my desk. "vacuum control assembly" Quote Link to comment
