Lozer Posted August 26, 2014 Report Share Posted August 26, 2014 Hey guys I have a set of 9.5x17 +54 offset vett rims (spares) sitting here with nothing to do. I also have a 71 510 wagon with some crappy tires and tiny 13 inch rims that wont fit the 280zx brakes i have. So after searching around for a bit I'm wondering if anyone could enlighten me as to what mm spacer i might need to try to cram these things in the hole? I also have some 17 by 8.5 +54 but they have no rubber. Thanks in advance. Quote Link to comment
banzai510(hainz) Posted August 26, 2014 Report Share Posted August 26, 2014 If you remove the fenders/cut the rear open and spend alot of money on some adapters(5 lug) and spacers Long bolts you might get these FREE wheels to work. Or just buy some cheap Rotas/ Enkeis/XXRs that fit in the fist place 1 Quote Link to comment
datzenmike Posted August 26, 2014 Report Share Posted August 26, 2014 Generally you can go one wheel size up maybe two to 15". After that they start to look ridiculous. The car was never esthetically designed for over 13" rims. Never never never make the car fit the rims. The car is everything, the rims are nothing just a fashion accessory. If they don't fit.... THEY DON'T FIT. 1 Quote Link to comment
qwik510 Posted August 26, 2014 Report Share Posted August 26, 2014 Sometimes Free is too expensive 1 Quote Link to comment
Lozer Posted August 26, 2014 Author Report Share Posted August 26, 2014 Yea I figured it wouldent be cheap or easy. And the spacers are as much as a set of rims. Quote Link to comment
datzenmike Posted August 26, 2014 Report Share Posted August 26, 2014 If they are available sell and fund some that do work? 1 Quote Link to comment
