Feels like autumn.
  • Please log in to reply
804 replies to this topic
#801 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
  • Cars:1968 510 sedan (RIP), 1972 510 goon, 1980 280zx,1976 280z (sold) 1979 620 kc (sold)
Posted 21 September 2017 - 10:48 PM
I had like 30 minutes so I got my aos where I want but I need to get an elbow that fits into the cannon manifold with a 3/8 nipple to connect the other side.
The car is gonna be on a major hold while I go to school. I’ll probably do super small stuff to it and turn it on every so often. It’ll always lurk in my mind. I can’t wait to upgrade rear brakes and get these damn carbs going .
https://flic.kr/p/YXecuz
Located in SoCal.
Just trying to figure it out.
#802 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 05 October 2017 - 11:38 AM
I'm going to lose the siderafts and put on a 32/36 dgv just because it's easier to tune and I'll be able to drive the car more.
I've got a bunch of goodies coming and that I was able to get for stupid cheap so it was worth it.
I won't touch the car because I'm currently in school but I plan to definitely make some game changes as far as my cooling system and carb setup.
I'm also planning to an alternator upgrade because my volts are reading 12 and the zx alt just doesnt put out as much as I'd like for everything I use.
I'm gonna run an inline thermostat sensor just because they're more accurate as far as coolant. I'm gonna make some hard fuel lines to make a cleaner setup.
I eventually wanna get longer spark plugs that don't sit on top of my valve cover but I don't know where I'd even get those and that's not as important as the car working.
I still more than just about anything want a rear disc setup for a wagon. I hate drums more than life lolll
On a side note, i picked up a set of 5 14x6.5 +6 Advan a3a for an unbelievable price so I'm gonna go with gun metal centers and polished lip.
Figured it would be a nice setup.
Sidenote: No, im not gonna sell my dellortos, I'm gonna get them jetted and venturies set to match my l20b setup and run them again down the line but I'm not that knowledgeable about these carbs. A 32/36 is the first carb I ever rebuilt so I'm just really familiar with it. I want to drive the goon!
Located in SoCal.
#803 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 05 October 2017 - 06:14 PM
Get universal plug wires that you assemble yourself, then you can make the wires whatever length you want
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#804 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 27 December 2017 - 12:57 AM
I haven’t been able to work on this car much since I don’t live near it.
with that said I got a few things done.
One issue I’m concerned about is how the rear disc swap works for the 510 wagon. I used the brackets and removed the backing plate entirely.
Meaning that my axle only has a bearing and it’s into the housing through just that. Can anyone explain to me how the wheel doesn’t fly the hell off?
Located in SoCal.
#805 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 27 December 2017 - 11:39 AM
So... unfortunately, I realized I wasnt supposed to completely cut off the backing plate on the wagons.
Lesson learned.
With that said, does anyone have pictures of backing plate and/or know the ID of the backing plate hole?
I'm going to create a piece of 1/16th or 1/8th metal piece that I can just cut the center hole and drill four holes along the sides in order to hold the bearing into position.
I was also concerned with the lengths of the actual axle bolts holding the bracket. Is there a way to get longer ones or maybe get something a bit safer?
Located in SoCal.
