Feels like autumn.
  • Please log in to reply
804 replies to this topic
#781 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
  • Cars:'71 510 Goon, '90 240SX, '85 720, '69 Roadster, '96 Pathfinder, too much other shite
Posted 29 August 2017 - 09:24 AM
Yes that is terrible. When your lights are on you aren't really charging the battery much if at all. If the demand from the car is higher than what the alternator is producing, you will be discharging your battery at times. Car batterys don't do well under that kind of use and it shortens the life drastically.
Your alternator should always be above 13.5V if it's running correctly.but no higher than 14.8V or so.
Half Pint ('71 510 Goon) http://community.rat...agon/p?=1269361
Audrey ('69 Roadster 1600) http://community.rat...rey-the-ratster
Tiny Havok ('85 720 DIY built Crewcab 4x4) http://community.rat...ache/?p=1395455
720 Shenanigans http://community.rat...20-shenanigans/
#782 thisismatt
thisismatt
    Senior Damon
  • Senior Member
  • PipPipPipPipPip
  • 7,572 posts
  • Cars:'71 521, '69 521 donor
Posted 29 August 2017 - 12:32 PM
Insufficient output or excessive draw from your lights for the given alternator output.
I'm your huckleberry.
One jump ahead of the lawmen
That's all, and that's no joke
These guys don't appreciate I'm broke
#783 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
  • Cars:1968 510 sedan (RIP), 1972 510 goon, 1980 280zx,1976 280z (sold) 1979 620 kc (sold)
Posted 29 August 2017 - 01:46 PM
I wired my lights through a relay so I really assumed that they would have minimal drawing paper.
I'll have to get my alternator checked soon and go from there I suppose. Thanks.
Located in SoCal.
Just trying to figure it out.
#784 q-tip
q-tip
    shark-tip
  • Senior Member
  • 14,483 posts
  • Cars:72 ka'd 4dr 76 620KC
Posted 30 August 2017 - 05:08 AM
Is it only 12.5 at idle or does it go up with some more rpm?
I yeald to the wisdom of Q on this one.
Fuck!!!!!!!! I guess QTip was right...
#785 Crashtd420
Crashtd420
  • Senior Member
  • PipPipPipPip
  • 1,711 posts
  • Cars:1972 Datsun 521
Posted 30 August 2017 - 05:33 AM
A relay is only a switch, it will not help with the amount of current the headlights use..
But it is good to use if you have a larger current draw then the factory switch intended. Then you don't burn up the switch or blow fuses....
How many amps is your alternator?
Is it an upgrade?
I am pretty sure my stock 521 alternator only produces 30amps...
So if you have upgraded lights, a stereo or a combination of anything else you may need a higher amp output alternator to take care of the current drop....
#786 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 30 August 2017 - 12:44 PM
I'll have to check when I get home to the car next week.
Located in SoCal.
#787 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 30 August 2017 - 12:46 PM
Is it an upgrade?
I believe it's the 60 amp off the 280zx that's internally regulated. I do have upgraded lights and I also have a few switches and I would have all my gauges.
That being said, I am using a super small battery off of a Harley to get the car going but then I figured that wouldn't matter much because it's only to start the car?
Located in SoCal.
#788 Crashtd420
Crashtd420
  • Senior Member
  • PipPipPipPip
  • 1,711 posts
Posted 30 August 2017 - 04:36 PM
Not sure how much, if at all, the size of the battery effects your problem, I think like you said it's really only to start the car..
Maybe try a bigger battery to rule it out but I'm not convinced that's your problem.
I still think you drawing to much with the lights....
Switches and gauges are a minimal draw....
How much are the lights suppose to use?
I compare this to my daily drive (chevy)...
It had a 100amp altenator... I have a pretty loud stereo system in it.... 75% volume I could watch my voltage drop with the bass...
When it finally died they offered me one for a truck with a plow package which was 140 amps....
Now I can turn my stereo up to 100% without a flicker of the gauge....
So either you alternator is not putting out 100% anymore or those lights require a lot more power....
Check the directions it should list it's power needs...
Then probably have the alternator tested?
Also have you configured the lights different from what they intended, like being able to have high and low on at the same time....?
#789 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 02 September 2017 - 05:44 AM
These are some great points. The car is set to have high and low at the same time HOWEVER I've only been running the low beams and completely unplugged the highs. This continues to happen. I'll look into upgrading to a gm regulator or get mine tested. I'd rather get the car driving correctly first, then upgrade alternators but this could very well be the answer. Thank you so much.
Now as far as the car driving, you guys said it could be "too much carb for the car" meaning that I'm running too rich? Should I try to lower the mixture screw and raise the idle screw to compensate? I don't know how to tune carbs too well but I do have a uni-syn tool that i use to help me get the numbers right. My synchrometer works much better. For some reason, my uni-syn's ball that's supposed to float doesn't even move.
Located in SoCal.
#790 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 06 September 2017 - 07:16 AM
Is it possible that what I need for the car to really run good is a good carb tune?
Located in SoCal.
#791 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 06 September 2017 - 08:29 AM
I was also thinking of re jetting as a potential option?
Located in SoCal.
#792 Crashtd420
Crashtd420
  • Senior Member
  • PipPipPipPip
  • 1,711 posts
Posted 06 September 2017 - 09:00 AM
If your not sure about tuning maybe get a baseline reading at a dyno shop. That will give you good info about your air/fuel, and which way you need to go with rejetting or tuning
Or if you like spending money invest in a wideband o2 kit.....
For me I went with the o2 kit because no one around me can tune a weber..
Ideally you can find a dyno shop that has jets for your carb ( sorry no idea what carb you have) and help tune while your there....
#793 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 07 September 2017 - 01:39 PM
Thanks. That's a huge help.
Also, why does no one run the Isuzu brake upgrade on h190 rear ends for a 510? They would work the same and fine essentially.
Located in SoCal.
#794 Lockleaf
Lockleaf
    Hall Monitor
  • Senior Member
  • PipPipPipPipPip
  • 4,451 posts
Posted 07 September 2017 - 06:54 PM
Lug pattern seems the most likely reason
#795 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 07 September 2017 - 11:52 PM
Ahhh that would be true wouldn't it lol
Located in SoCal.
#796 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 08 September 2017 - 12:00 AM
Anyone got an idea where they sell 280zx rear disc brackets?
Located in SoCal.
#797 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 10 September 2017 - 09:50 AM
I got a Flickr. Here's updates. Just recently dyed and got the black e30 seats in. Gotta install my aos and a few more things. That wire hanging is for a hazard switch that I'll do soon. I wanna get this car to run better. Anyway to make e30 seats sit lower?
Not sure how to post in img format
https://flic.kr/p/Ykup7L
https://flic.kr/p/YADw6k
https://flic.kr/p/YkuqqN
https://flic.kr/p/XjJXW1
https://flic.kr/p/XZuya3
https://flic.kr/p/Yo59Xc
https://flic.kr/p/YiW12w
https://flic.kr/p/XZuxe5
https://flic.kr/p/XZux3o
Located in SoCal.
#798 Draker
Draker
    Ratsun-Erect
  • Senior Member
  • 12,758 posts
  • Cars:1971 2 door 510, 1969 4 door 510, 2002 Tacoma double cab
Posted 10 September 2017 - 09:55 PM
The goon is looking good!!
View my 69 510 4dr Sedan - Build Thread
View my 71 510 2dr Sedan - Coming soon.
http://drakers.pl510.info
#799 DatMo
DatMo
  • Senior Member
  • PipPipPipPip
  • 1,813 posts
Posted 11 September 2017 - 12:01 AM
Thanks! Hopefully I can get more of it sorted out! I'm wishing I could daily it already.
Located in SoCal.
#800 Crashtd420
Crashtd420
  • Senior Member
  • PipPipPipPip
  • 1,711 posts
Posted 11 September 2017 - 04:12 AM
That's the worse when your so close....
I took my 521 for a joyride around the block.... with nothing more than a cab on a complete chassis.... the itch to drive it is awfull now....
