67_520 Posted August 22, 2014 Report Share Posted August 22, 2014 I was just wondering if there is anybody out there that makes aftermarket upper and lower control arms for the 520? I have a bagged 520 and really wanting to get away from the king pins. All of my research has turned up empty this far so any help is appreciated Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 Took me 5 seconds to type 521 control arms into search engine.... http://community.ratsun.net/topic/44397-fs-full-set-upper-and-lower-control-arms-from-beebani-bnib/ BEEBANI is the guy to see about this. There are other threads on this swap. Quote Link to comment
finney Posted August 22, 2014 Report Share Posted August 22, 2014 Whats wrong with the king pins? actually allows more travel than a ball joint front end. My Lower "stock" Lowers - running stock uppers, Quote Link to comment
67_520 Posted August 24, 2014 Author Report Share Posted August 24, 2014 I just simply don't want to run stocks. I want away from kingpins and into ball joints because they are a lot easier to change. As well as being able to run much better brakes. And I want something that just looks better. Quote Link to comment
finney Posted August 24, 2014 Report Share Posted August 24, 2014 I'm currently converting my 520 to Toyota pickup brakes and hubs, Only needs one collar machined for the rear of the 520 stub and swap the front bearing from the 520 into the pickup hub 4 pot callipers - just need to start on the mounting brackets. Quote Link to comment
