85"720 Posted August 21, 2014 Report Share Posted August 21, 2014 What kind if diff oil should I use in my truck Quote Link to comment
datzenmike Posted August 21, 2014 Report Share Posted August 21, 2014 GL-5 80w90. Synthetic will often begin leaking past an old seal. Quote Link to comment
85"720 Posted August 21, 2014 Author Report Share Posted August 21, 2014 Thanks mike. Any brand that you would prefer? Quote Link to comment
datzenmike Posted August 21, 2014 Report Share Posted August 21, 2014 Name brand. They all have to perform to minimum EP requirements on the label. Quote Link to comment
85"720 Posted August 21, 2014 Author Report Share Posted August 21, 2014 I'm probably gonna get royal purple Quote Link to comment
datzenmike Posted August 21, 2014 Report Share Posted August 21, 2014 If synthetic be warned that that stuff is so slippery it can leak past seals that would normally hold ordinary oil. I've done this. A few weeks later the diff was all wet. The cure was replacing the pinion seal with a new one. Did the same with the transfer case $25 X 2 seals. The trans had a new rear seal, I always change them when the trans is out. It's only $5 Quote Link to comment
85"720 Posted August 22, 2014 Author Report Share Posted August 22, 2014 Mines only has 113k original miles would it still leak or just stay with the regular stuff Quote Link to comment
85"720 Posted August 22, 2014 Author Report Share Posted August 22, 2014 Also how many bottles Do I need Quote Link to comment
datzenmike Posted August 22, 2014 Report Share Posted August 22, 2014 Two wheel drive 1.25 liters..... 2 5/8 pints US Four wheel drive 1.30 liters..... 2 3/4 pints US Quote Link to comment
85"720 Posted August 22, 2014 Author Report Share Posted August 22, 2014 Thanks mike for the help Quote Link to comment
