76_620 Posted August 19, 2014 Report Share Posted August 19, 2014 Checked all my fuses cleaned fuse box l, checked soddering connection on steering Colum dnt know what else it is ! Need help also aftermarket stereo not turning on ? Quote Link to comment
datzenmike Posted August 19, 2014 Report Share Posted August 19, 2014 Swap the 4 way emergency and the turn signal flasher. If the problem switches to the 4 way then the flasher is bad. Forget checking the fuses. Replace them. Fuses, specially fuses that are almost 40 years old, are not to be trusted. Quote Link to comment
76_620 Posted August 19, 2014 Author Report Share Posted August 19, 2014 Swap the 4 way emergency and the turn signal flasher. If the problem switches to the 4 way then the flasher is bad. Forget checking the fuses. Replace them. Fuses, specially fuses that are almost 40 years old, are not to be trusted. Quote Link to comment
76_620 Posted August 19, 2014 Author Report Share Posted August 19, 2014 I replaced all fuses too, how do I exactly swap the 4 way flashers with the turn signals ? Quote Link to comment
datzenmike Posted August 19, 2014 Report Share Posted August 19, 2014 Both are side by side under the dash beside the steering column. They might still be clipped together, just unplug (2 wire plugs) and swap. Quote Link to comment
datzenmike Posted August 19, 2014 Report Share Posted August 19, 2014 Small aluminum can or may be replaced with newer plastic king Quote Link to comment
76_620 Posted August 20, 2014 Author Report Share Posted August 20, 2014 Both are side by side under the dash beside the steering column. They might still be clipped together, just unplug (2 wire plugs) and swap. Quote Link to comment
76_620 Posted August 20, 2014 Author Report Share Posted August 20, 2014 Awesome man I appreciate the help that was it !! You're awesome and have quick help response :) Quote Link to comment
datzenmike Posted August 20, 2014 Report Share Posted August 20, 2014 It's why I get up every day. 1 Quote Link to comment
