Tech-guy Posted August 18, 2014 Report Share Posted August 18, 2014 On the brake hydraulic distribution block located on the left side of the engine bay, what is the electrical connection for? I cannot find it on any of the wiring diagrams that I have been able to find. Quote Link to comment
Guest Rick-rat Posted August 18, 2014 Report Share Posted August 18, 2014 It would probably help if we knew WTF this is for. Toyota, Subaru, Ford, Chevy????? Quote Link to comment
tr8er Posted August 18, 2014 Report Share Posted August 18, 2014 This one? this is only a switch to tell you that either your front brakes, or your rear brakes have lost hydraulic pressure. It's a two sided pressure switch. That is all this does, along with splitting the front brake line into two brake lines. The electrical connection triggers a light in the instrument panel. In US it says "Brake" I believe. Mine used to be where the tach, or clock goes. Not sure where it goes on a stock manual car. Quote Link to comment
