68 dime cluster
Looking for a 68 dime cluster.The one I have the fuel n temp don't work. I have a couple of choices to see if they can be repaired or replaced. Fuel maybe a sending unit as well as the temp. Not sure how much they run new or used. Anybody have suggestions as far as trying to fix/repair or buying new.
  • Replies 8
If both the fuel and temp gauge do not work, check the in-dash voltage regulator. When that goes out, it screws with both gauges. It regulates the 12v down to something like 8.3v I think.
If you search the how-to section, there is a thread in fixing it. There's a member here who sells replacements.
Thanks I'll see about making him about the fix. I found 2 others that are selling there used ones bit pricey. So I gotta try the fix forst
the fix is solid state new technology and should work forever
no more open and closing of the contacts to get the proper voltage
Also if looking for parts we have a CLASSIFIEDS section for that. Asking questions about your problems go here, electrical or the 510 forums but buying and selling is over there.
