Break in engine oil
DATSUN671
  • Replies 12
Get 15w40 Rotello T or Chevron Delo 400. It's a light diesel oil with lots of ZDDP in it to protect our cam and followers from wear.  Newer oil formulas have less ZDDY every year. Break in oil is not used today. Get the engine running properly and take out on a highway (as soon as you can) with lots of room and accelerate hard in 3rd gear up to speed and slow down to 30 staying in 3rd. Repeat 20 or more times. If in town, run in lower gears and vary the speed at all times. Accelerate and slow down in the same gear. Check oil and water often. Make the engine work hard as this will thrust the rings against the cylinder walls wearing them in and making a good seal. Do not baby the engine, as this will extend or even prevent proper break in. Change the oil and always the filter at a few hundred miles.
The Brad Penn has lots of the ZDDP as well.  All the machine shops that I know of recommend it for break in.  We rebuild about 15 Porsche engines a year(small mechanic shop) and have had good results so far. I'm not sure how hard it is to get Brad Penn on the west coast, didn't really think of that :P
Back when our Datsuns were new the ZDDP level was way over 1,000 PPM. As high as 1,600 ppm. Today's oil is from zero to 600/800PPM and falling. By today's standards 900 would be high.
1,100 PPM would (I think) be minimum safe for flat tappet cams and followers. The alternative is worn off cam lobes and grooved followers.
Back when our Datsuns were new the ZDDP level was way over 1,000 PPM. As high as 1,600 ppm. Today's oil is from zero to 600/800PPM and falling. By today's standards 900 would be high.1,100 PPM would (I think) be minimum safe for flat tappet cams and followers. The alternative is worn off cam lobes and grooved followers.
For the ones who's don't know what zddp and ppm mean can you decode that for me plz :)
ZDDP is an abbreviation for an oil additive that contains zinc, and phosphorus.   This additive bonds to metal and prevents metal to metal contact, most importantly where the cam lobes slide directly across the rocker arm pads.
PPM=Parts Per Million.
Modern engines do not have a metal  to metal contact like our Datsun L-engines.  They do not need ZDDP.
In an engine with high miles, that burns a little oil, if you have high ZDDP, it will poison the catalytic converter.  So, as the levels of this additive were brought down, engines changed to not require it as much.
Modern engines need modern oils.  Older engined need older formulas of oils.
  • Like 3
