521 vs 510 radiator question
Just a quick question for y'all.
My 521's Radiator got a small leak. Looking to replace it with aluminum. Will I be able to use a radiator for a 510? I can alter the mounting it it's not too majorly different.
I did check and they're different part numbers, so just wanted to be sure before spending $300+
Thanks
  • Replies 13
Lol, just ordered a 3 core Koyo about 2 hours ago. :)
Wise man, and im surwe you already know this but just in case you didn't if your going to add water to the new radiator fluid make sure it's purified water. It's better for the coolant system it doesn't have all that extra crap which wares down and rust cooling parts.
The glycol in antifreeze is supposed neutralize all the crap from tap water, but unfortunately not all of it. You can't use distilled water though 'cause lacking all the minerals to allow it to cool properly. Running tap water through a filter is the best you can do without wasting a lot of money on purchased water.
