69 dash question
  • Replies 1
The radio goes in the dash from behind. You're missing a horizontal bracket that runs through the middle of the radio opening. The radio goes behind that... The plate your holding goes in front of the bracket. You then have two very thin nuts (basically threaded washers) that screw down over the radio selector knobs posts that are now sticking through both the bracket and the fascia piece in your hand. Then you pop on the radio knobs.
So you need to fabricate the bracket back into your dash and you need to install the stock radio.
