1980 B310 Daily Driver with NEW PAINT
Nascarkeith
I am a new Datsun owner and want to see if I am Ratsun worthy. I have a 2007 Silverado that is paid for and had a motorcycle for a toy. Sold it and wanted to get something I could play around with and that my daughter can ride in. I scoured craigslist and local Facebook groups looking for old Hondas and ran across my Datsun. :thumbup:
Here it is when I got it.
61b14f14-3bb2-4edd-8eeb-189578edfa74_zps
10588564_10203610773462371_1334993335_n_
10581717_10203610773782379_26297873_n_zp
Known issues-
Oil Leak
Interior lights no worky
Brake light stays on
Air don't work
Leaking coolant
Radio mounted in floor
Rear tires worn
Quarter window handle broke
Window crank broke
Front seats duct taped with covers
Rust on bottom of doors
I got it home and showed it a little tlc. I put some led's in the dome light and the dash lights came on except the climate control. A new bulb fixed that. I put the radio in the dash but it was so dry rotted I busted some of it. Changed the oil. The leak looked like it was coming from around the oil filter. Washed it, cleaned it up, and painted the grill, headlight trim, and area between the tail lights black. I removed the trim and painted a black strip and also painted the rust white. I also zip tied the loose quarter window, took the ugly weather guards off, and fixed the window crank. Added lots of stickers, too.
ba6ca72d-40f6-48c2-9729-791be42d56a4_zps
5cb6e67a-2b20-4ca0-8c82-1927c8960962_zps
cccb0434-cddf-483c-8a41-946d57737f72_zps
The good-
Extra parts in trunk = grill, struts, clutch assembly, clutch disk, brake shoes, universal joint, 6x9's in boxes
It only cost me $400
So what do you all think? Did I get a good deal? Is it Ratsun worthy?
  • Replies 50
Yep. I know about Rock Auto. Thanks for the help, though. I'm sure I will need it.
I did some research and realized there should be a plug to connect to the oil pressure switch. Wiring for that plug is non-existent so I resoldered the hole close and covered it with JB Weld for good measure. We shall see if it still leaks.
Welcome! Join the rest of us 210 owners here: http://community.ratsun.net/topic/21813-210s-unite/
I've got a few spare 1/4 window latches. Yours for the cost of shipping if you want them. I just archived and put away all my spare parts over the weekend so I'll know exactly where to find them. I can shoot you some pics tomorrow in you're interested.
As for the window crank you can get some on ebay. 720 pickup window cranks also work with the B310 AND they're generally metal. Early round eye 210s came with metal cranks as well. The square eye most always came with plastic :(
Thanks, Colourbox. I'll remember that if I decide to mess with it more.
Great info guys.
Not sure about the coil. Was on there when I got it. Looks like a previous owner did some hp mods. While working on the oil leak I saw a Weber decal on the carb. I also believe the timing is advanced.
Someone mentioned putting a quarter on the brake switch to fix the blinkers. How does that work? My blinkers are amber and above the brake lights. Left side flashes. Right side comes on but doesn't flash.
You said brake lights stay on. The plug that closes the circuit always falls out.
Place a quarter under brake light switch to fix.
Ah, I wasn't specific enough. It's the brake light on the dash. Sensor on e-brake is stuck I assume. Master cylinder looks to be full.
With the Weber carb, big coil, and electric fan I believe an old owner might have done some reading on here.
Thanks to all of you for being welcoming and super helpful. I am having fun learning about Datsuns.
Forgive me if I am posting too much.  I just like to document all my builds on forums whether it be rc, motorcyle, or car.
I washed and waxed it today.  Did what I could in the engine bay and cleaned up the interior.  Trim rings have been cleaned with a SOS pad and wheels were painted with Rustoleum Metallic Dark Steel spray paint.  I also painted the area around the windows black.  Oil change and work on oil pressure switch stopped the leak.  New air filter was put on.  Carb has been cleaned.  Some new plugs and it should be set for the fall and winter.
21280bd9-6029-43e1-9fbe-bd96c4f1384b_zps
2e23cec5-62e8-4a22-811f-1e5f0f369f3e_zps
78d0e599-9b5e-4dbf-b61d-b3105418c722_zps
0fcbd818-7e53-4ddb-a805-5a5e1aec3d45_zps
53574540-9e04-4fa2-8d2f-8bf1f0725b0d_zps
What is the key hole on the drivers side behind the door for?  No of my keys fit it and I can't find an answer from friends or online.
Yeah, I've googled and still no luck.  Not exactly sure what that could be for.  No other signs of an alarm in the car though.
Got the blinkers fixed.  Just had to clean the terminals.  They were very corroded.
I changed my plugs.  Runs much better now.  I thought with the new plug wires on it the plugs would have been changed.  I was wrong.  I can't believe it ran as good as it did.
41996017-b73c-4883-922f-55d1b61d6230_zps
I also looked through the parts that came in the trunk and found some cool, chrome window visors.  Nice little added bonus.
386c9725-c084-4250-939f-462d0b42133c_zps
4d88f882-ca4e-4f56-b2a5-3439a98abc81_zps
Known issues-
Oil Leak
Air don't work
Leaking coolant
Rear tires worn
Window crank broke
The good-
what's the price?
cool score any how!
